Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Re: Possibly dumb temporary/removable gooseneck hitch idea
welding man
10-07-2011 16:54:26
As far as the foreward and and backward movement, you would probably be Ok, but what about the tongue weight. If you are talking about installing this in a pickup I think you would probably bend the bottom of the bed badly,unless you used an awfully large plate.say 4 ft x 8 ft. you can buy a hitch a lot cheaper.
scotc
10-08-2011 15:50:30
 Re: Possibly dumb temporary/removable gooseneck hitch idea in reply to welding man, 10-07-2011 16:54:26
There were a lot of square plates the width of the frame rails bolted to the bottom of the bed before there were custom-fit mounts for goosneck hitches available at three or four shops in every little town.
AS for the idea, I'd say scrap it. You would need some pretty stout tubing to take the thrust from the trailer, the tie-downs and chains would actually do the locating of the ball. The set-up to the reese hitch wouldn't do much, because it can't hold off any side draft. And you have no direct connection of the hitch to the frame.
Why not set up a tow dolly with the hitch permanently fastened to it?
