farmer boy
I have a 1997 GMC sierra K1500 with a 6 lug 14 bolt rear. The current springs are worn out and sit on the axle with a 1/2 ton of feed on it. I found some leaf springs out of a 2000 nbs 2500. Eye to eye they measure 62.5 inches (not installed) and are 2.5" wide The springs on my truck are 2.5 wide and 63.5 inches(installed). Will these springs swap with each other? How much(if at all) will the truck go up. I wouldn't mind an inch or two but don't want any more than that. I don't want to be able to load more on. Just don't like the suspension to bottom out every time you put the trailer on it or put some feed it. Makes you a target for the MTO.
