TractorLinks.com
hauling a Case DC
Flewster
07-25-2011 10:41:42
I will be hauling a Case DC 215 miles this friday. Never transported a tractor before. Anyone got good advise or pictures on the way to tie it down? Thanks
Flewster
07-28-2011 20:16:57
 Re: hauling a Case DC in reply to Southtowns27, 07-25-2011 10:41:42
Installed chains on the rear as you described and then put the clevis in the front and installed a heavy duty 10,000 pound strap up there. Headed out in the morning. 16 foot dual axle trailer. put rear axle of tractor over rear axle of trailer. Just a bit of weight on tongue.
Flewster
07-25-2011 21:05:54
 Re: hauling a Case DC in reply to harvestmoonpuller, 07-25-2011 10:41:42
Thank you.
Tommy Railsback
07-25-2011 13:07:47
 Re: hauling a Case DC in reply to Flewster, 07-25-2011 10:41:42
If it's a narrow front, I do the front this way:
Look underneath the casting the radiator sits on; you will see 2 parallel pieces with holes directly
across from each other. Take a clevis and pin and put it there and run your front chain through the clevis.
For the back, I go around the corners of the drawbar frame with my chains. I do not recommend a clevis on the drawbar itself; in fact, I have heard that that is illegal.
