Topic: Re: electric brake problem
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| johndeerefan
07-17-2011 10:25:05
63.141.72.111
It can only be 1 of about 4 things
1. The power wire for the break away switch is wired to a hot or turn signal wire. It should go from + on kit battery to pull switch, then to trailer brake wire. If you have a charger type one, make sure the other + wire doesn't go to trailer light or signal wire. It should go to the 12V prong on the trailer plug.
2. The brake light/brakes wire is tapped into the turn signal wire. Turn signal wires should run from the trailer plug to only the turn signal lights!
3. A bad ground wire somewhere. Grounds cause all kinds of mysterious things. You should have (1) common good ground on the trailer. See below.
4. One of the plugs are wired wrong. Here are some diagrams to go by. Use a read out type tester, don't use a light tester when checking. http://www.offroaders.com/tech/trailer_wiring-diagram.htm
Make sure you run a good ground wire from the trailer to the plug ground prong and then a ground wire from the truck plug ground prong to the truck frame. This will ensure a good ground. Letting the trailer ground to the truck ball is not a good way to do it. Plus it will keep lights, turn signals, etc from flickering or being weak. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
