Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Transporting Discussion Forum
Topic: electric brake problem
[Return to Forum]
model-b
07-14-2011 18:27:14
208.102.211.62
Have a gooseneck trailer with electric brakes. everytime i would turn on turn signals or lights the brakes would come on. I have replaced the plug on trailer and new wires to all lights still does it.In the mean time have bought a new truck and everytime i put the four ways on the brakes come on i am stumped dont know what to check now any ideals. Thanks
[Reply]   [No Email]
johndeerefan
07-17-2011 10:25:05
63.141.72.111
Re: electric brake problem in reply to model-b, 07-14-2011 18:27:14
It can only be 1 of about 4 things
1. The power wire for the break away switch is wired to a hot or turn signal wire. It should go from + on kit battery to pull switch, then to trailer brake wire. If you have a charger type one, make sure the other + wire doesn't go to trailer light or signal wire. It should go to the 12V prong on the trailer plug.
2. The brake light/brakes wire is tapped into the turn signal wire. Turn signal wires should run from the trailer plug to only the turn signal lights!
3. A bad ground wire somewhere. Grounds cause all kinds of mysterious things. You should have (1) common good ground on the trailer. See below.
4. One of the plugs are wired wrong. Here are some diagrams to go by. Use a read out type tester, don't use a light tester when checking. http://www.offroaders.com/tech/trailer_wiring-diagram.htm
Make sure you run a good ground wire from the trailer to the plug ground prong and then a ground wire from the truck plug ground prong to the truck frame. This will ensure a good ground. Letting the trailer ground to the truck ball is not a good way to do it. Plus it will keep lights, turn signals, etc from flickering or being weak.
  [Reply]  [No Email]
scotc
07-15-2011 20:40:19
72.100.47.174
Make a jumper for hot and ground to a battery, pull the plug off the trailer, and science out what wire does what, then wire it up properly. Your brakes are getting power from the brake/signal lights instead of the EBC wire. It could also be in the breakaway kit.
Is your controller lighting up when you are having your brake issues? If it is, check the grounds. A gooseneck at work would lock the brakes as soon as you hooked it to the one truck. It would also lock them when hooked to my truck and any power was put to the trailer. Turned out the cord hadn't been unplugged and the truck driven away, the tug broke the ground wire in the junction box, and it was backfeeding the EBC to find ground.
  [Reply]  [No Email]
bobs old iron
07-14-2011 21:41:18
75.171.159.49
the problem isn't replacing the plug-ins, you need to take truck-trailer to a trailer shop to make sure wires match up with factory specs to trailer wires....some trailer companies use the wrong color wire sometimes confusing you..... depending if you have a 4-5-6-7 pin connector.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
