Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
safety chains
kyles
07-05-2011 22:07:41
In Missouri do you need safety chains on a gooseneck trailer. 30ft 20,000 axels ball coulper not king pin.
mkirsch
08-07-2011 19:54:52
 Re: safety chains in reply to kyles, 07-05-2011 22:07:41
The breakaway cable should be secured to the truck at a point separate from the hitch, so that if the hitch rips off the truck, the breakaway cable will activate the breaks on the trailer.
chucksoliver77
08-03-2011 12:34:39
charles or anyone who knows is the proper place to hook the break away cable? chuck
J.Wondergem
08-02-2011 05:21:25
 Re: safety chains in reply to jd plowboy, 07-05-2011 22:07:41
If he's able to haul 26,000 lbs and over, he needs a CDL anyway.
730d se
08-02-2011 05:05:58
Unless it is being pulled under the "farmer within so many miles" rule, the driver will need a CDL even when empty. If the drive has a CDL, he (or she) will know the rules.
charles todd
07-16-2011 05:24:32
I bought an older home built goose from Texas. Registered it is Louisiana with a VIN number. When the VIN was stamped on the trailer, it became a 2008. This required it have safety chains.
I bought the hangers/weldments and the safety chains from a local trailer manufacturer. I also bought a breakaway kit as well. The hooks for the chains MUST have a spring loaded snap inside the hook. My chains are 3/8".
CT
Oldmax
07-16-2011 04:35:08
According to some on the internet not in WV, but I still use them on all my trailers.
bobs old iron
07-06-2011 13:15:11
chains are required if a ball set-up is used....i have a 5th pin set-up on my goose, because i have r-v also, don't need chains, but i still attach to 5th wheel frame in case the state patrol takes a look see while driving next to me... with chains down, chances are they won't stop and look...but it still good idea to hook onto somthing, just for saftey also.
mkirsch
07-06-2011 05:56:29
That is correct. 5th wheel trailers (i.e. "king pin") do not require safety chains.
d beatty
07-06-2011 05:44:54
If you have the king pin setup you don't have to use safety chains.
Rich Iowa
07-06-2011 05:22:37
I agree with ericlb and believe it's a nation wide requirement. I know of a lot of gooseneck hitches that were farmer installed that don't have attachment points for safety chains. Most of them just hang the chains down into the bed.
ericlb
07-06-2011 05:07:30
as far as i know safety chains are required on all trailers in all states
JohnnyfromMI
07-16-2011 09:49:32
 Re: safety chains in reply to ericlb, 07-06-2011 05:07:30
Really?? Have you ever seen safety chains on a semi tractor fifth wheel trailor?
