Yesterday's Tractor Co.
Shop Now View Cart
Tractor Transporting Discussion Forum
Re: Look at I found
Rich Iowa
07-03-2011 08:12:09
Thank you Sir. I knew I'd be doing a rebuild at some point, just not so soon. The truck will stay in stock form and only see occasional pulling duty, but I will upgrade the tranny a little so this doesn't happen again.
07-03-2011 09:25:10
 Re: Look at I found in reply to Rich Iowa, 07-03-2011 08:12:09
Sir? Where?
They are actually fairly durable. They just need regular fluid changes. And don't use the transmission to stop it changing directions, use the brakes.
Put a good torque converter in it. The lock-up on the stockers is a bit weak, then they slip and put debris through the rest of the system. It's a cellulose(I.E, paper)-based friction material. Do some looking around online, I don't know if they build dual or triple-disk convertors for the gas engines, but there are better ones than the stock ones.
Rich Iowa
07-04-2011 20:04:24
 Re: Look at I found in reply to scotc, 07-03-2011 09:25:10
I ask the same question when people call me Sir. I never use a transmission to stop a vehicle before changing directions. Good way to ruin one in a hurry.
07-06-2011 19:12:17
 Re: Look at I found in reply to Rich Iowa, 07-04-2011 20:04:24
My uncle did all the plowing we did with the truck, and believes the brakes just get you stuck.
Two trucks, 9 years, 3 clutches and 4 automatics.
Brian Jasper co. Ia
07-10-2011 06:58:16
 Re: Look at I found in reply to scotc, 07-06-2011 19:12:17
Unless each one of those trucks has a million miles, 4 transmissions in 9 years is pretty poor. 3 clutches in the other one doesn't sound like much to write home about.
Rich Iowa
07-07-2011 04:45:04
I haven't done a whole lot of plowing with a truck but sounds like he needed better tires or more weight if he was worried about getting stuck.
07-07-2011 20:07:02
 Re: Look at I found in reply to Rich Iowa, 07-07-2011 04:45:04
Lake effect snow belt. You push it way the heck back from the start so you have room to push it back later. You can fix the yard come spring.
