| Tractor Transporting Discussion Forum |
Topic: Re: Ford Engine swap
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Stuart
06-25-2011 05:07:36
64.198.86.189
Hey I completely understand your position. They were a good motor, hard on fuel but would pull very well. All I am saying is they dont hold a candle to a newer diesel. 454,427 and ford 460s were good motors and if taken care of will still give many years of service. |
| F-350
06-25-2011 06:36:36
67.142.179.25
Re: Ford Engine swap in reply to Stuart, 06-25-2011 05:07:36
| | I have several friends with almost new F-350 Fords and 3500 Dodges...They are only getting 8-10 mpg pulling not that heavily of loaded trailers ..They now wish they had their older diesels back as they were getting 12-15 mpg with them.. My 460 Ford gets about 7 mpg towing if I stay some under the speed limit..It loves fuel but has plenty of power..If I used a truck more I would have a late 90's Dodge or Ford diesel. |
| CMMC
07-17-2011 03:07:56
155.148.33.73
Re: Ford Engine swap in reply to F-350, 06-25-2011 06:36:36
| | Tell your friends to invest in a good chip and couple upgrades! My old (by today's standards) 97 Powerstroke has some rather cheap upgrades, Superchips Tuner, Turbo and Intercooler from 99+ powerstroke, intake, and less restrictive down pipe from the turbo. I can honestly say that I have done close to double the mileage your buddies are gettin with a hell of a load. I don't drive like a mainiac with all that weight either. Let them know, that is if you want to lose your bragging rights. All in good fun, Mills |
| Stuart
06-30-2011 08:59:35
64.198.86.189
| 2003 Dodge 2500 Cummins 6 speed manual trans. 3.73 gears. 18mpg AVERAGE not max. |
| The tractor vet
06-27-2011 05:53:57
76.212.226.187
| I can tell ya this, the 88 F350 4X4 that i had did a great job on towing once we got the bugs worked out of it but that took five computer changes and i was using a computer from a 92 . The trck was a cab and chassi i built a 9 foot steel flat bed with a wood floor for it and built in every hitch you could think of even one for off set towing of hay bines and corn pickers balers . It had 4.10 gears with a 5 speed . I use to deal in used farm equipment and i was on the road atleast once a week to sales in Indiana or Ill. Some weeks i was changing oil in the truck twice with the miles i was running . Fuel mileage was always recorded for each trip . Empty truck no trailer she avg. 14 , with trailer 12-13 loaded 9-12 depending on what was on the deck.The worst she ever got was on a load i brought out of Plymouth ind. , it was a E gleaner with corn head and a 10 foot header . Loaded the header over the goose neck as the corn head was on the combine and then drove the combine on the trailer and tucked the corn head up under the grain head . There was a really stiff wind blowing out of the east that evening and when i pulled out of the sale lot i could not believe how hard it was pulling across U S 30 , I could hardly get to 60 mph with my foot to the floor . Both tanks were full and she was eating gas . She sucked down both tanks before i got to the east side of Ft. Wayne . Pulled into a small fuel stop to feed the beast and she took 35.8 gallons on a 36 gallon system . Started thinking that hey i doubt that i would make Beaver Dam sucking fuel like that . So just for the heck of it i unloaded the combine and backed on and chained her down and took off . That made all the difference in the world as how it pulled and the next stop for fuel was Canton . Now the other thing was that i had done some work on the 460 that shell we say did not meet the EPA guidelines . Like i had changed the cam timing back to 69-70 spec.'s and i ran the total ing. timing advance at 36 degrees at 2000 and i also ran high test . I never towed in 5th when loaded and tryed to keep engine rpm at between 32 and 3400 rpm . I now have a 95 Dodge 3500 4X4 with a 12 valve Cummings with 4.10 gears (bad choice for gears ) and i can tell ya that on a good day empty truck running around empty the BEST she has ever seen has been 14 MPG. I can also tell ya this a couple weeks ago was the first time i have ever towed with this truck and we used her to haul fertilizer a 26 mile round trip and hauled five rounds at around 12000 lbs each load and sucked up 32 gallon of fuel . My buddy's 2001 Dodge 3500 4X4 cab and chassi with a 9 foot aluim. flat with 3.54 gears and a 5 speed with his big free flowing exhaust and his CHIP get on the avg. of 16and maybe 17 mpg. Then old 460 took six qt. of oil per change and a three dollar filter the Cummings takes 10 qt. and a eight dollar filter and a 23 dollar fuel filter Diesel is 3.89 here and hightest here wright now 3.49 . The old Ford took one battery and the Dodge takes two . Now when i bought the Dodge Diesel was less then gas BUT NOT NO MORE. Been thinking real hard about selling off the Goat . The longer i keep it the more i find that i do not like about it . |
| Stuart
06-30-2011 09:02:38
64.198.86.189
Re: Ford Engine swap in reply to The tractor vet, 06-27-2011 05:53:57
| Yeah but you can also run a cummins to 15,000 miles on oil changes per the manual. I run 7500 miles. not 3000 like a gas engine. I get 18mpg empty all the time. With 18,000lbs I averaged 14 mpg. 16 empty and 12 full. I you had the 6 speed with 3.73 gears you may get better mileage but at 62 or so my tach is at 2000 rpms. |
| The tractor vet
06-30-2011 20:40:23
99.167.210.166
Re: Ford Engine swap in reply to Stuart, 06-30-2011 09:02:38
| Well sofar myself i have not seen anybody around here getting much over 17 with a 3500 with a aluim flat with 3.54 gears and a 6 speed and as for towing i know for a fact that as set from the factory STOCK the old 460 would plum EAT a cumming alive . As back in 96 we went to a tractor pull down south of here and i had the Minni Mo U loaded to 75-7600 and my S/Mta loaded to 9000 the old Ford weighted in at 7500 lbs and my Blair goose neck weights in with all chains and binder at 7500 , THat is around 31000 the pull in Carrollton was a morning pull and then the one in Lisbon was and evening pull . The U pulled in four classes and the S/Mta pulled in three loaded up and set sail for Lisbon this is HILL country . One guy from Pa beat me out the gate with his New Dodge Cummings one ton 4X4 with one Farmall M on the deck i passed him on the long hill . |
| Stuart
07-01-2011 05:51:28
64.198.86.189
Re: Ford Engine swap in reply to The tractor vet, 06-30-2011 20:40:23
| I have 400 hp with mine and my dad is a huge ford 460 fan and even at stock my Cummins will beat him easily and his is engine has been played with a bunch.But on the upside your 460 wont last near as long as my Cummins. I will go head to head with you and you will stop for fuel more than I will. The newer cummins dont get the fuel mileage of the old ones.At 400 hp a Cummins will still last to over 600k.I have seen that done with my own eyes. There is a reason that there are way more cummins out there than 460s.But hey if you like your old truck, more power to ya. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
