Yesterday's Tractor Co.
Shop Now View Cart
Tractor Transporting Discussion Forum
Re: Carlisle trailer tires
06-21-2011 21:07:29
I'd call around to the local tire shops and see if I could find a decent set of used truck tires. Put a set of good Coopers on a trailer a couple years ago, that I would not have hesitated to run on the truck. If they were the right size. All 4 mounted for $100, 225/75R16E.
Brian Jasper co. Ia
06-26-2011 19:31:00
 Re: Carlisle trailer tires in reply to scotc, 06-21-2011 21:07:29
You're probably right on a practicality point of view, but the DOT doesn't always see things practically, or even with common sense.
07-02-2011 02:56:03
 Re: Carlisle trailer tires in reply to Brian Jasper co. Ia, 06-26-2011 19:31:00
ST tires are made with a compound that doesn't dry out as fast when it's sitting, and the sidewalls may be a little stiffer.
As long as the tire has a load rating high enough for the load, meets minimum tread depth, and is properly inflated, with no cords exposed, what can they say?
There are all kinds of semi trailers running around with under-spec steer tires (tires on a steer axle have a deeper minimum tread depth than drive or trailer tires per DOT), drive tires that lost their mates, and recapped steer and drive tires out there. Are they going to take all those out of service? I don't think so.
07-22-2011 21:52:06
 Re: Carlisle trailer tires in reply to scotc, 07-02-2011 02:56:03
They guys I know that used to mix compound for Uniroyal disagree with you. The "trailer tire mix" was the left overs from all the other batches run. Think of trailer tire compound as analogous to pot metal. Anything left over was just tossed in. They ran trailer tires when the scraps piles started to overflow. I can't imagine that the products from China are better or produced differently than what Uniroyal used to make. Could be wrong, but...
