Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Transporting Discussion Forum
Topic: Re: 4500lb tractor + 2200lb trailer. 7k trailer or 10k?
[Show Entire Topic]  [Return to Forum]
F-350
06-20-2011 07:39:00
67.142.179.20
You haul stuff your way and we here in the midwest will haul stuff our way..We must have lots better roads and much less traffic than you do..
Going 10 mph under the speed limit causes no problems here..Its flat level farming country and people can pass most anytime they want to..I get 2-3 mpg better staying 10 under..Theres farm machinery on the roads going 20 mph all the time..
Only twice in the past 4-5 years have I had to pull over and let people by..I was over 100 miles from home in a very hilly area..I pulled over in small towns and let traffic by..I had tall loads and the wind was blowing 40 mph and I couldnt make any headways...This was with a crew cab dually and a 14K gooseneck..
My brothers new F-150 has a combined 16,000 towing capacity..It weighs around 6000 so that leaves him 10000 lbs for a trailer and the load..He wouldnt have any problems pulling a 4000 lb tractor a few times a year on a 7K car trailer..Its done all the time around here with no problems..For a few times a year you dont buy a 3/4 ton or dually with a 10K or 14K trailer..
I just got rid of a 7K car trailer that I used for over 20 years..All that was ever done to it was repace the floor once,pack the bearings,replace tires,and keep the lights and brakes working..It was never once welded on.
I have a neighbor that has bought and sold small tractors for many years..He has a nice 7K tilt bed 16 ft bumper hitch that he pulls with a 1500 Chevy..It doesnt take a semi to haul an 8N Ford..
[Reply]   [No Email]
buickanddeere
06-20-2011 11:29:26
192.75.48.150
 Re: 4500lb tractor + 2200lb trailer. 7k trailer or 10k? in reply to F-350, 06-20-2011 07:39:00
"You haul stuff your way and we here in the midwest will haul stuff our way..We must have lots better roads and much less traffic than you do..""
So the laws of physics don't apply to xenophopes?
"For a few times a year you dont buy a 3/4 ton or dually with a 10K or 14K trailer"
The trailer and truck is either overloaded or it's not. One inspection by the DOT will prove that.
Overload anything into the yield point of metal and it will rapidly fatigue and fail. It's not a matter of if, just when. Tires will rapidly deteriate when overloaded. You can't see the failure of belts and rubber inside from the outside.
[Reply]  [No Email]
JimEvans
06-20-2011 19:00:13
66.185.0.208
 Re: 4500lb tractor + 2200lb trailer. 7k trailer or 10k? in reply to buickanddeere, 06-20-2011 11:29:26
There you go calling people names again. Kind of a pot and kettle thing.
The 1/2 ton with a 4000 lb tractor is NOT overloaded. You why do you keep bitching? Maybe you should read some of the posts before you respond.
[Reply]  [No Email]
F-350
06-21-2011 06:40:02
67.142.179.25
 Re: 4500lb tractor + 2200lb trailer. 7k trailer or 10k? in reply to JimEvans, 06-20-2011 19:00:13
Well Jim our friend just doesnt seem to get it...When he
doesnt get his way he likes to call names...Its been that
way for years..He must be related to Plowboy on
Newagtalk..
I guess if he had bought a new 4020 JD in the 1960's he
would have only pulled a 3 bottom plow with it because a
5 bottom plow would have maxed it out...There must have
been (50) 4020's in my area and they all pulled
5x16's...Even the 3020's pulled 4x16's and the 2510;s
pulled 4x14's...Yes,our soil is sandy and doesnt pull hard.
Its perfectly legal to haul a 4000-4500 lb tractor or load
of any kind on a 7K trailer pulled by a 1/2 ton pickup..Its
probably the most popular combination that I see...Many
years ago I towed with a F-100 Ford with a 3/4 ton
rear,heavy springs,and bigger tires...It did really nice..
If a nicely built 7k trailer weighs 2200 and the tractor
weighs 4000-4500 then he has 300 to 800 lbs to
spare..Every once in awhile I'm that close on my 14K
trailer...In fact just recently I was some over that for a 7
mile haul..
A 16 ft trailer isnt as maxed out as a 3/4 ton pulling a 25
ft 14K gooseneck with a 9-10,000 lb tractor on it or a
dually pulling a huge tandem axle trailer with 18,000 on
it..I see that all the time..You seldom see anyone only
using half the capacity..
I have a friend that is a new trailer dealer and he probably
sells (5) 16 ft bumper hitch trailers to every one of any
other size..His trailers are very nicely built..If you want to
go up in size he will gladly take your older trailer in trade
as he can quickly sell all the used ones he can get..
The guy asked what it would take to haul a 4500 lb tractor
and he was given plenty of answers..If thats all he ever
intends to haul a 7K trailer will do fine..If not he can
always trade up..Thats what I did..I have way more truck
and trailer than I need 90% of the time but I occasionally
haul some pretty big loads.
[Reply]  [No Email]
buickanddeere
06-21-2011 05:54:09
192.75.48.150
The topic started out as #1 Purchase just enough trailer to get by without any reserve capacity. Not being able to tow heavier loads in the future. And run equipment at or near it max rated limit. Continuous usage at max rated limit is a common factor in area equipment failure.
Or #2 For a few extra bucks purchase a hauling system that isn't maxed out.
[Reply]  [No Email]
JimEvans
06-21-2011 18:30:14
66.185.0.208
 Re: 4500lb tractor + 2200lb trailer. 7k trailer or 10k? in reply to buickanddeere, 06-21-2011 05:54:09
I think owning an old D8 Cat would be very cool someday. Unfortunately, I only have a 12k bumper pull trailer. I guess I really screwed up by not buying a new KW with a detach trailer. I promise to buy something that will cover all of my future needs next time.
You are correct that equipment that is maxed out will have a shorter life than equipment that isnt. Thanks for pointing that out. But I really only need my trailer to last 40 years. I really don't need infinite life. I have seen far more trailer tires blow out from old age than from being overloaded.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
