Yesterday's Tractor Co.
Shop Now View Cart
Tractor Transporting Discussion Forum
Re: Dual Use For Winch
Tramway Guy
06-19-2011 17:56:29
Is that actually 12000 lbs line pull, or 12000 lb. 'rolling load'??? Big difference!
Harold H
06-21-2011 06:21:18
 Re: Dual Use For Winch in reply to Tramway Guy, 06-19-2011 17:56:29
From the manual, rated line pull per layer of cable on drum. Layer 1 12,000#, layer 2 9,550#, layer 3 8,000#, layer 4 6,800#, and layer 5 6,000#. It has 100 ft of .375" 7x19 galvanized steel aircraft wire rope rated for 14,400 pounds. I received it yesterday afternoon.
Harold H
06-21-2011 06:43:04
 Re: Dual Use For Winch in reply to Harold H, 06-21-2011 06:21:18
you better see if that is breaking strength or working load limit, big difference.
Harold H
06-21-2011 16:08:20
 Re: Dual Use For Winch in reply to cd1, 06-21-2011 06:43:04
Working load.
Harold H
06-21-2011 18:24:43
 Re: Dual Use For Winch in reply to Harold H, 06-21-2011 16:08:20
Performance table: line pull lbs/line speed fpm/amp draw @ 12v: 0#/16.4fpm/72amp, 2000#/14fpm/115amp, 4000#/9.9fpm/159amp, 6000#/9.1fpm/198amp, 8000#/7.6fpm/242amp, 10000#/6.1fpm/281amp, 12000#/5fpm/320amp.
06-22-2011 08:04:15
 Re: Dual Use For Winch in reply to Harold H, 06-21-2011 18:24:43
what I am saying even on wreckers and the like, the winch will far out power what the winch line is capable of taking safely, so you use snatch blocks and so fourth. You can do a little looking on the net and find about what that line is rated for. I doubt it's what you think.
