TractorLinks.com
Tractor Transporting Discussion Forum
Re: Dual Use For Winch
smallercrawler
06-17-2011 15:48:33
Jim, your point is well taken. To minimize this I have done the following: Winch negative is solid welding cable from bumper plug to battery post; negative is grounded to truck frame rail at rear plug; both batteries have auxilliary grounds from negative posts to solid frame rail grounds. All ground conductors are welding cable, crimped and soldered to terminals, bolts use radially ridged lock washers on both sides of connections, all frame points were clean. Lots of overkill, buuuuut? Could fuse truck side of trailer plug ground pin at connector with fast blow. (Hitch/ball will also provide somewhat of a ground path.) You've got me thinking unplugging still might be the safest idea, thanks for raising the point; old adage about two heads better than one always applies.
