TractorLinks.com
Tractor Transporting Discussion Forum
Dual Use For Winch
Harold H
06-16-2011 09:14:46
For Father's Day I am giving myself a 12,000# winch which I am going to mount on a receiver hitch on the front of my Ford 4x4 pickup. My utility trailer currently has both a hand winch and a small electric winch, both of them together which have to strain to load a dead tractor or such. I am going to mount a 2" receiver to the front floor of the trailer so that I can use my new 12,000# winch for either a truck winch or a trailer winch. This should easily load anything that I need to pull up on the trailer.
Harold H
Tramway Guy
06-19-2011 17:56:29
 Re: Dual Use For Winch in reply to Harold H, 06-16-2011 09:14:46
Is that actually 12000 lbs line pull, or 12000 lb. 'rolling load'??? Big difference!
Harold H
06-21-2011 06:21:18
 Re: Dual Use For Winch in reply to Tramway Guy, 06-19-2011 17:56:29
From the manual, rated line pull per layer of cable on drum. Layer 1 12,000#, layer 2 9,550#, layer 3 8,000#, layer 4 6,800#, and layer 5 6,000#. It has 100 ft of .375" 7x19 galvanized steel aircraft wire rope rated for 14,400 pounds. I received it yesterday afternoon.
Harold H
cd1
06-21-2011 06:43:04
 Re: Dual Use For Winch in reply to Harold H, 06-21-2011 06:21:18
you better see if that is breaking strength or working load limit, big difference.
Harold H
06-21-2011 16:08:20
 Re: Dual Use For Winch in reply to cd1, 06-21-2011 06:43:04
Working load.
Harold H
06-21-2011 18:24:43
 Re: Dual Use For Winch in reply to Harold H, 06-21-2011 16:08:20
Performance table: line pull lbs/line speed fpm/amp draw @ 12v: 0#/16.4fpm/72amp, 2000#/14fpm/115amp, 4000#/9.9fpm/159amp, 6000#/9.1fpm/198amp, 8000#/7.6fpm/242amp, 10000#/6.1fpm/281amp, 12000#/5fpm/320amp.
cd1
06-22-2011 08:04:15
 Re: Dual Use For Winch in reply to Harold H, 06-21-2011 18:24:43
what I am saying even on wreckers and the like, the winch will far out power what the winch line is capable of taking safely, so you use snatch blocks and so fourth. You can do a little looking on the net and find about what that line is rated for. I doubt it's what you think.
Pitalplace
06-18-2011 07:22:06
 Re: Dual Use For Winch in reply to Shetland Sheepdog, 06-16-2011 09:14:46
I made my own receiver mount for my winch. Mounted a receiver on the trailer about 18 inches above the floor. This way I can use this winch where ever I want. I also have a receiver in a 3pt. hitch for my tractors. Right now it is setting on the floor chained to an anchor in my shop and I am using it to pull the car I am restoring back into the shop. It seems that it has been in and out of the shop several times for cleaning and painting projects. I broke down and bought a remote for this winch which makes this an easy job. Anyway I am so glad I did not mount this winch permanently to the trailer.
JimEvans
06-16-2011 18:11:48
If you use long "jumper" cables to power the winch, make sure you unplug the trailer plug before using it. If the ground cable isn't connected well, the 400 or so amps will try to travel back to the battery via the trailer plug connection. You will melt the wiring harness from the front to the back of the truck in about 2 seconds.
smallercrawler
06-17-2011 15:48:33
 Re: Dual Use For Winch in reply to JimEvans, 06-16-2011 18:11:48
Jim, your point is well taken. To minimize this I have done the following: Winch negative is solid welding cable from bumper plug to battery post; negative is grounded to truck frame rail at rear plug; both batteries have auxilliary grounds from negative posts to solid frame rail grounds. All ground conductors are welding cable, crimped and soldered to terminals, bolts use radially ridged lock washers on both sides of connections, all frame points were clean. Lots of overkill, buuuuut? Could fuse truck side of trailer plug ground pin at connector with fast blow. (Hitch/ball will also provide somewhat of a ground path.) You've got me thinking unplugging still might be the safest idea, thanks for raising the point; old adage about two heads better than one always applies.
JimEvans
06-16-2011 18:11:20
smallercrawler
06-16-2011 13:24:34
Hi Harold, I haul dead crawlers (usually) and the following has worked well for me: I suggest mounting the winch receiver about 18-24 inches ABOVE floor level (mine's on tounge just at rear of hitch, tag type trailer). This will give a straighter pull in most cases and will allow hooking lower on the dead tractor to more easily start it onto the ramps and get it over the ramp/deck transition; if using tounge high mount, deck length is not compromised, but WATCH tailgate/winch CLEARANCE on hills and turns. Also if not wireless, run a semi-permanent "extension cord" on trailer frame that plugs in/out of the winch on one end and has a plug at the rear of the trailer to plug the control pendant into; gives essentially longer reach on cable. One person can ride and steer them onto the trailer while operating the winch.
I put about 6 feet of appropriately sized chain with hook on the end of the winch cable to avoid cable kinks. Truck is wired for switched 225 amp service to rear bumper.Good luck.
rustyfarmall
06-16-2011 11:10:18
Sounds like a plan! I would suggest going one step further and mounting a 12 volt battery on the trailer to power the winch. Wire it right into the trailer wiring so the second battery gets charged from the truck, and then leave the truck running while winching those dead tractors onto the trailer.
cd1
06-16-2011 13:47:05
 Re: Dual Use For Winch in reply to rustyfarmall, 06-16-2011 11:10:18
you better look into battery isolators or something along those lines to keep it from pulling on your charging wire which is typically not heavy enough, or just unhook the trailer plug when using it.
VicS.
06-18-2011 19:58:55
 Re: Dual Use For Winch in reply to cd1, 06-16-2011 13:47:05
I have a old 8000 Warn, I made a mount for a receiver hitch. I also have a battery mounted on the winch. and a receiver on my trailer. We don't use it very much but when we do, it saves the day.
