Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Transporting Discussion Forum
Topic: Re: RE: 5 or 6 speed
[Show Entire Topic]  [Return to Forum]
Walter Buller
06-01-2011 21:22:22
99.195.58.155
Of course I could be wrong, but I think I can finish the job for under 3K. I found a well preserved 95 Chevy 3500 for $500, and a complete 1993 5.9 12v Cummins with 202K for $800. Assuming the NV 4500 costs maybe $750, and my mechanic charges $600 as he claims, I'll have about $2700 in it, plus a set of tires. Sure, it would be much easier and more convenient to buy such a rig outright, but I've not seen one around here, or on the net, except for a Cummins Ford for $4100. So I'll do this the slower and hopefully cheaper way, pay as I go, no notes, and then know what I've got when we're done.
[Reply]   [No Email]
WayneB
06-02-2011 06:13:03
132.159.85.115
 Re: RE: 5 or 6 speed in reply to Walter Buller, 06-01-2011 21:22:22
Yes, but there are also incidental costs. Motormounts, AC filter/dryer, new pump perhaps and freon, slave cylinder perhaps, fluids, not to mention the cost of re-sizing drive shafts. Alignment check, etc.
It will be quite a good deal.
When I finished mine, I was amazed at how well it drove, performed and over the years, the consistency of performance and longevity. The Cummins 5.9 12V is such superior engine.
Before you set a Cummins 12V with 202K, go to the Dodge or Cummins dealer and get a crankcase ventilation filter. It is a baffle plate that goes on the left side of the engine up under the injector pump. While it is only 6 bolts, a plate and gasket (@85.00) it is very difficult to replace in the engine bay. The lower pump brackets has to be removed, as well the lift pump. Will prevent front & rear main seal and gasket leaks later.
Keep us posted on your build. I'd be interested your approach to intercooling and fan setup.
Wayne
[Reply]  [No Email]
ericlb
06-07-2011 04:49:30
75.107.64.57
 Re: RE: 5 or 6 speed in reply to WayneB, 06-02-2011 06:13:03
wayne, i would like more info on this ventalation plate, ive not known about it and my cummins has started leaking from the rear main seal, is one supposed to be replacing this thing periodicly?
[Reply]  [No Email]
WayneB
06-11-2011 20:36:28
67.142.174.21
 Re: Crankcase Ventilation Baffle in reply to ericlb, 06-07-2011 04:49:30
I replace mine recently. The engine probably has near 300K or more. My engine started leaking from everywhere. I was getting no pressure out my road draft tube. Could blow back through the ventilation filter with an air hose, with the filler cap off, and the engine would quit leaking for a while. Replaced it and the leaks stopped. It was clogged when I pulled it.
Engine starts with a bump. And since I put the engine in in 2004, I have never needed to hook up the grid heaters. Runs great. Just pulled a trailer 2200 miles without adding a drop of oil.
On the 24v and later the crankcase vent filter is a replaceable filter. I'd say Cummins recognized an issue and changed the engineer drawings.
[Reply]  [No Email]
Walter Buller
06-03-2011 18:29:56
99.195.58.155
I asked my mechanic about your suggestion of changing the gasket on that baffle plate. He said that we could certainly do this all right before installing the motor, but that in 60 years of making his living as a mechanic, and rebuilding every size of Cummins motor from those in pickup trucks to semi's, and larger, he has almost never seen that gasket start leaking. Have you had a different experience?
[Reply]  [No Email]
Stuart
06-07-2011 05:29:54
64.198.86.189
 Re: RE: 5 or 6 speed in reply to Walter Buller, 06-03-2011 18:29:56
What specific years are you talking about? I have a 2003 Cummins, do I have to do this? Thanks
[Reply]  [No Email]
WayneB
07-03-2011 08:07:27
67.142.174.21
 Re: RE: 5 or 6 speed in reply to Stuart, 06-07-2011 05:29:54
after the 12V, Cummins put in replaceable crankcase ventilation filters. No need to pull the baffle. Cummins must have recognized it as a problem. On the TDR site, when 12Vs were the most driven, it was a common write up. On mine, the gasket did not leak, it was the front and rear main, and other places. My dipstick would blow out.
I could blow air up the vent tube with the filler cap off, and it would be OK for a month or so. The metal filter in the baffle was "growed up." Other than being the first time, and very hard to get at, the job is simple. Six bolts. THe fuel pump, the oil sender, the bottom pump bracket must come off. I would not call the job hard, but I would call it a PITA job. Took me all day. I think the second time, I could do it in 4 hours.
Wayne
[Reply]  [No Email]
Walter Buller
06-08-2011 09:24:06
99.195.173.170
1994
[Reply]  [No Email]
Walter Buller
06-02-2011 12:13:05
99.195.58.155
10-4. And thanks heaps for the info.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
