Tractor Transporting Discussion Forum
Re: 10,000
Ken Macfarlane
06-01-2011 04:58:52
I should add, these are 4wd automatic cummins swaps so you need:
-new rad
-new mounts
-front and rear dshaft work
-computer to run the transmission
-a/c brackets
-specific manifold to fit the turbo in the right place
-new rad unless you had a big block in it
-New front springs unless you had diesel
-Exhaust work obviously
-Tach signal adapter
-Hydroboost brake conversion unless you want vac pump brakes
-dozens of other little things
06-03-2011 18:57:10
 Re: 10,000 in reply to Ken Macfarlane, 06-01-2011 04:58:52
Actually, as long as you use an A518 or an RH transmission, they are hydraulically controlled, except OD and lock-up, if it has it. You can use 2 pipe fittings, pressure switches, and a couple other switches in the cab to control both OD and lock-up, for well under 50 bucks.
Walter Buller
06-03-2011 18:43:59
Negatory. This is a 2WD conversion using a 5 spd. NV-4500 tranny.
