Yesterday's Tractor Co.
Shop Now View Cart
Tractor Transporting Discussion Forum
Re: Chevy-Cummins.
05-30-2011 05:51:57
Details: Engine must be mount almost touching the firewall. AC pump needs trimed to fit. Every frame cross-rail from engine back has to be moved rearward and drilled/bolted. Rear driveshaft shortened and front lengthened. I run a 18" solid fan flush mounted with short cummins fan mount. Stock radiator. Tach runs thru the alternator. I keep thinking about cutting my radiator support and mounting a Cummins Dodge 2004 intercooler in front of my radiator (have it). I run 4" exhaust. Mileage is same or better than 6.5 16-20 empty, @14 towing. She has pulled more than the average pickup. Had a fellow ride in my truck who owns a 2003 Cummins Dodge. He was amazed at the ride quality and comfort. He had ridden in my GMC Topkick and he likened his ride to my Topkick. I'll do another converson if I every wear this one out. :)
Walter Buller
06-03-2011 17:58:04
 Re: Chevy-Cummins. in reply to WayneB, 05-30-2011 05:51:57
Why did you not run a 5" exhaust?
06-11-2011 20:52:50
 Re: Chevy-Cummins. in reply to Walter Buller, 06-03-2011 17:58:04
I put the 4" exhaust in my truck when I built my 6.5L up to 300 HP. Yes 300. All I did when I dropped the Cummins in was change the downpipe.
That 6.5 with a Peninsular diesel boat injector pump and turbo would run circles around this 5.9 empty. HaH, Not loaded. And it would not hold up. Made more out of it in parts than I had in it. 6.5 = P.O.S. Parting it financed my conversion.
05-31-2011 10:13:36
Another SMALL detail.
88-98 Chevy/GMC conversion require a minimum 2" cab lift. Had everything installed back in 94 and the hood wouldn't close. Cab lift kit is super ez to install, and improves the truck appearance; IMHO.
Walter Buller
06-03-2011 18:31:49
 Re: Chevy-Cummins. in reply to WayneB, 05-31-2011 10:13:36
Thanks for the tip.
Walter Buller
05-30-2011 10:18:18
Thanks heaps for the info.
