BANDITFARMER
I have read many posts about Cold Hard Srarts on a 7.3(1996 F350 auto) but mine starts up great cold its when you drive it 20 miles and shut it off and try it 10 min later it dosent want to start. It acts like its starved for fuel and will start after a mininte of cranking and its off to the races. If the truck sits 20 to 30 min it will start right up with no problem. To answer some questions I have traced the fuel line for defects, Has new fuel filter, cam sensor, back pressure sensor, oil temp sensor, T stat and temp switch, glow plugs and G plug relay. Oil and filter have been changed and has good oil pressure I even put a new throttel padel sensor in and still have this problem. The truck only has 82000 miles on it and this dosent make any sence to me. Has anyone had this problem or have any idea what it could be? I am at my witts end! Bandit
