johndeerefan
Here's the deal. I bought a new 18' equipment trailer last year and ordered it with a break away kit factory installed. I noticed the other day it would not active the brakes when the pin was pulled. Logically, I took out the battery and fully charged it. Put it back in and same results. I have contact sparks on the contacts inside the breakaway switch when I pry them apart with a screwdriver. Thinking I had a short somewhere, I hooked the trailer plug up to the truck plug (did not latch the ball). The brakes seemed to work like they should and always have. Yes, all four brakes hummed. I was getting something like 1.6 output volts (will go to max brake voltage setting by using the manual brake slider), 1.5 output amps, 12.?? battery volts, and 12.?? brake voltage on my P3 diagnostics. I had it hooked to my newly purchased used truck, so I am not sure these results really reflect the true numbers I was getting before with my other vehicle. As I thought the output volts and amps should be higher when using the truck brake pedal. But the truck was turned off and sitting still. It would take about 3 seconds for the output amps and volts to change, the battery and brake voltage were instant. Although, the trailer brake hum was delayed by the pedal unless I used the manual slider on the controller. I can't remember if that was normal before. Seems like it was.
I even thought the wiring from the breakaway switch to the brake wire splices was bad. So I removed them and checked them. They seemed okay. Put them back on and you can hear an instant click on the brakes, but no humming when you pull the pin. Yes, I removed my trailer/truck plug before pulling the pin to keep from destroying my controller. I even thought I had the wires backwards, so I reversed them. When I pulled the plug, the side marker lights would come on. I thought this was caused by backfeeding into the taillight/parking light wiring. As the brakelights are tied into the brake wiring. So, I switched it back.
My breakaway kit is wired as follows: Switch wire to battery positive. Switch (other wire) to trailer brake wire (spliced in with connector). Battery ground to trailer ground then it also spliced into other brake wire (I assume that is the ground for the brakes).
Any suggestions on where to go now? I have went around and wiggled all the wiring, but the brakes still won't hum with the pin pulled.
