I've got a tandem axle utility trailer that the electric brakes do not work on. It originally had 1 brake axle. I just added the brakes to the rear axle as well as trying to get the front axle brakes to work again. Of the 4 drums, I think they all buzz, and 1 actually locks up (driver side, front axle) when I freely spin the tires. They are all adjusted tight to the point or dragging some. Does the problem lie in the wiring? They are not backwards; the actuator arm is facing forward on all 4. The supplier I got the new hub/drums from said just wire in the new ones, doesn't matter which magnet wire goes to ground and hot.
This is just confusing me since 1 of them is actually working
Thanks
Thanks
