hualing a haybine
BLT
I am wondering if it is possible to hual a 7 or 8 foot cut haybine not sure which model, mabey a 472 or 488 on a car type trailer. It is 18 foot long with 79 inches between wheelwells the wheelwells stick up 9 inches higher than the deck. Can a haybine be picked up with a front end loader or will that damage it?
Seen many a haybine hauled that way. Yes if careful and you have a big enough loader it can be picked up and set on a trailer. The tongue will need to be removed or it will hang out way to far to be able to be hauled. I have also seen dolly wheels set up to make loading one on easier.
Hobby farm
I looked at a picture of one, and it looks like you can load it from the side onto a car hauler trailer. It will be easier if the fender on the side you load from can be removed for loading. After backing it on you will need to remove the shaft and tongue. If you can't back it on from the side, you can bring some lifting straps and either pick it up with a loader, or hang it from something strong and back the trailer under it.
