Pulling a tractor
Hi,Has anyone ever made a tow dolly to pull a tractor.? I don't know why I couldn't make one to put the back wheels on and drive slow. Does this sound doable? thank you
If you check the archives you should find many references to tow dollies made for narrow front tractor with the front tires on the tow dolly. In my memory most
had a pair of 14 or 15 inch tires and a hitch pin similar to a wagon for pulling. Drive the tractor on the pan between the two wheels, fasten it down, put the
tractor in neutral, and drive.
Depending on the model that is not such a good idea. Newer models like the ones with hytran in the rearend for luberication with a certain amount of oil flow from the MCV pump it will ruin the bearings in the rearend. They rely on the pump for oil supply. Older letter and earlier number series like the 00,50 series will work that way. With the 80/90 oil.
He said the rear wheels. JD4020 have a tow position. Yes, a car dolly like you pull a car behind a motorhome would work for.a.smaller tractor.
Unless you was doing this often, and
not very far, I wouldn't mess with
trying to do it. And if I did, I think
I would rig up something to put front
wheels on the dolly.
With the rear wheels on a dolly and the front on the ground with oil steering it will drift as the oil shifts from the steering and he will be using 2 lanes for the job instead of the one he started out on. Now with the older direct connect steering like on a 60 series and back or the older fords and such yes he could do that though I don't see why if it is that close just drive it. He does not say anything about a certain tractor model that I read. Also pulling it backwards will have the toe in for the tires fighting and wearing more than if they were in the correct direction. Again just drive it or load it.
Yes there was a company that made them but I cant
remember the name right now . If not done right you can
destroy enough parts to buy a trailer to haul it on and at best
you wouldnt want to go very far or fast . If its a really small
tractor thats dead somewhere Id just get a car dolly
Yes but that tow position doesnt really have anything to hold it in tow position either I wouldnt pull mine with its life depending on it very far without someone in the seat to make sure it stays in tow position.
Finally made it out to the shed that i keep my 2 dolly's in and took a pic of them, 2 different styles, but the same idea. I generally only use them to pull a couple tractors to a local show that i attend
Those dollies shown must be a garden tractor if he's going to put the rear wheels on them. Those are made for narrow front tractors with no swivel on them. They are figuring on the front wheels for the swivel on those. Will still be a pretty good jump to push them up on that with them up 8-12 inches high hooked to the truck if no ramp on it. All this fooling around just load it and go. You will be happier in the end.
I borrowed one that you run a narrow front tractor into. He advised me not to pull the tractor any faster than 20 mph (about the speed of the tractor in road gear). I only pulled my tractor about 15 miles. It worked alright. About the only thing you gain is you can do it alone. If you're going very far, see if you can rent a trailer from a friend.
Hey there! It's great to see your interest in making a tow dolly to pull a tractor. While I haven't personally made one myself, it is definitely doable with the right knowledge and skills.
When building a tow dolly, it's important to consider factors like weight capacity, stability, and safety. You'll need to ensure that the dolly can handle the weight of the tractor and provide proper support. It's crucial to design and build a sturdy frame and a secure attachment mechanism for the tractor.
Additionally, make sure to comply with local laws and regulations regarding towing and trailer requirements. Double-checking with relevant authorities or seeking advice from experienced builders can help ensure that you meet the necessary safety standards.
If you're confident in your fabrication skills and have access to the right tools and materials, creating a tow dolly for your tractor is definitely within reach. Just remember to plan carefully, prioritize safety, and consult resources or experts when needed.
Best of luck with your project, and I hope your tow dolly turns out to be a valuable addition to your tractor equipment!
