Gentlemen,
I have been given a Farmall H Tractor close front end by a family member about 150 miles away. In need of a trailer to transport
it. Any suggestions of a company that rents trailers much appreciated thank you.
Bob
If the engine doesn't run but isn't locked up put a 12 volt battery on and use the starter to load it and use 1st gear. Done that to at least 10 tractors over the years and NEVER had a problem doing so as long as you wheel for minute then stop and wait a minute to do it again
I would think that a local equipment rental company would rent you a trailer to haul the tractor. I would get an outside to outside measure of the rear wheels to get a trailer wide enough to haul it.
