Lost a few teeth on the fifth gear . Everything else looks pretty good inside I?m going to go ahead and replace the mainshaft fifth gear as well as the countershaft mating gear even though it looks fine . Also going to go ahead and put a new input shaft in and reset the end play to spec .
With these little five speeds it?s common consensus to not tow heavy in fifth or overdrive but I do because I?m limited to about 55 which is fine for most hauls but I still like to run in overdrive
