Farmall 300 plus sickle mower haul
toplink
Need to see if anyone is making a run from or through the Tecumseh, KS area towards the Piedmont North Carolina area. Trying to get a haul estimate on a running Farmall 300 and sickle mower which will be attached to the unit.
Thanks,
Tim
Hi Tim: I do some hauling. Would be interested in hauling your tractor and mower to NC. I may have another item to haul to NC as well. My tel.# 785-564-1784. I live in Manhattan,KS
Okay, I'll give you a call, probably tomorrow Jerry. I have a friend in the area that is going to lay eyes on it, so I'm just trying to hook up with a load coming this way.
Tim
I have had great luck with something called uship.com but you will have to sort thru a few responses. Eventually I always find someone making an empty back haul or similar. The hauling schedule here works too.
Yeah, I put it up for bid on there, but the price wasn't reasonable for what I was buying.
Thanks though. I had to pass on the deal.
Tim
Hey Jerry, I apologize for failing to call you today. I had to pass on the deal. If you are interested in it since you are closer, let me know and I'll put you together with them.
Tim
