Toddweber99
New User
This message is a reply to an archived post by Howard H. on April 09, 2012 at 11:30:51.
The original subject was "F350 7.3 Diesel".
I have a 2002 that had power problems. I am still learning about diesels. My mechanic found bare wires in the harness by driver side wheel well and I have been doing research and found a bad IPC sensors and pigtail. Replaced these and my truck is now back to doing hole shots on dry pavement. However now my teams is not shifting right since sensor replacement from 2nd to 3rd. It is a very short shift and this is a new problem. Truck has 144,000 miles on it and we do light towing of a 2 and 3 horse trailer. Hoping it's just a bad sensor for transmission.
I replaced the following this past weekend
IPC sensor
IPC sensor pigtail
Cam sensor
Tensioner
Idler pulley
Added aftermarket air filter
Truck is better than when I took it off show room floor, now just need to figure out shift issue which is new today
IPC sensor
IPC sensor pigtail
Cam sensor
Tensioner
Idler pulley
