Chuck Reynolds
All,
I am wanting to haul a john deere 4430. Believe the weight is around 12000-13000 lbs. Need to buy some lever binders (boom) and tractor supply had some rated at ~9200 lbs. They also had a ratchet binder rated the same.
Remember reading that a QUANTITY of 3 or 4 binders is needed legally to haul a tractor. I want to use the right number and the right ratings.
Should I have a BINDER rated greater than or equal to the tractor weight?
Also, the binder CHAIN seem to be rated 6600 lbs. Should I find a chain rated greater than or equal to the tractor weight?
Any guidance is appreciated.
Thank You
Thank You
