TractorLinks.com
Tractor Transporting Discussion Forum
Re: want to protect new floor on trailer
D beatty
05-11-2014 13:34:30
You asphalt fence post paint is really not much better than used motor oil. Number one it is made from an industrial waste called coaltar. If you go to the asphalt fence paint and read the Tech Data Sheet It says "Harmful if you breath vapors and if it comes in contact with eyes or skin". It also contains chemicals known to cause cancer and birth defects. So I would say its no better than used motor oil.
soundguy
05-11-2014 14:06:01
 Re: want to protect new floor on trailer in reply to D beatty, 05-11-2014 13:34:30
fortunately you are incorrect.. nor did you read my post.
The co i work for deals with both used oil and asphalt on a dialy basis.. I have the MSDS sheets in front of me..
When cured it is virtually inert, and NON reactive with respect to leaching and offgassing volatiles.
the product is classified as :stable
at ambient temperatures the product does not decompose.
HAZARDOUS POLYMERIZATION: Will not occur
STakes a STRONG oxidizer to make it reactive.
A4 Not Classifiable as a Human Carcinogen
Bioaccumulation of components is not expected
This material, if discarded as produced, is not a RCRA “listed” hazardous waste
Not regulated by the U.S. Dept of Transportation as a hazardous material
EPA SARA 311/312 Title III Hazard Categories:
Chronic Health Hazard: NO
Fire Hazard: NO
Pressure Hazard: NO
Reactive Hazard: NO
NATIONAL FIRE PROTECTION rates it as a health 1, fire, reactivity 0
Flash Point:
N/A
Flammable Limits In Air % By Volume:
Lower: N/A
Upper: N/A
Material:
Stable
Conditions To Avoid:
N/A
Hazardous Decomposition Products:
N/A
SECTION VIII - SPECIAL PRECAUTIONS AND SPILL/LEAK PROCEDURES
Spill or Released:
Allow to cool and remove.
As i said. it's pretty safe when it's not 400 degrees...
Used oil MSDS:
HEALTH HAZARDS
May be harmful if absorbed through skin.
May be harmful or fatal if swallowed.
May irritate eyes, and skin.
Suspect cancer hazard. Contains material which can cause cancer. Risk of cancer depends
on duration and level of exposure.
Contains material which can cause birth defects.
Contains material which can cause central nervous system damage
ENVIRONMENTAL HAZARDS
Product may be toxic to fish, plants, wildlife, and/or domestic animals.
POTENTIAL HEALTH EFFECTS
Effects may vary depending on material composition. Typical effects may
include:
EYES: May cause irritation.
SKIN: May cause irritation. Product may be absorbed through the skin and cause
harm,dizziness, loss of coordination, numbness, and other central
nervous system effects. Massive acute overexposure may cause rapid central
nervous system depression, sudden collapse, coma, and/or death.
INGESTION May be harmful or fatal if swallowed
MEDICAL CONDITIONS Individuals with pre-existing cardiovascular, liver, kidney,
AGGRAVATED BY central nervous
EXPOSURE: system, eye, and/or skin disorders may have increased
susceptibility to the effects of exposure.
CHRONIC: Prolonged or repeated eye contact may cause
inflammation of the membrane lining the eyelids and covering the eyeball
(conjunctivitis). Prolonged or repeated skin contact may cause drying,
cracking, redness, itching, and/or swelling (dermatitis).
CANCER This product contains mineral oils, untreated or mildly treated, which can
INFORMATION: cause cancer. This product may contain hydrocarbon and chlorinated
solvents; metals, and polynuclear aromatics which can cause cancer. Risk
of cancer depends on duration and level of exposure. For more
information, see SECTION 11: CARCINOGENICITY.
POTENTIAL ENVIRONMENTAL EFFECTS
SECTION 5: FIRE FIGHTING MEASURES
FLASH POINT: >200°F (93°C) (minimum) Pensky-Martens Closed Cup
HAZARDOUS COMBUSTION Decomposition and combustion materials may be toxic.
PRODUCTS: Burning may produce phosgene gas, nitrogen oxides, carbon
monoxide, and unidentified organic compounds.
SECTION 6: ACCIDENTAL RELEASE MEASURES
Remove all ignition sources. Do not touch or walk through spilled product. Stop leak if you can
do it without risk. Wear protective equipment and provide engineering controls as specified in
SECTION 8: EXPOSURE CONTROLS/PERSONAL PROTECTION. Isolate hazard area.
Keep unnecessary and unprotected personnel from entering. Ventilate area and avoid
breathing vapor or mist. A vapor suppressing foam may be used to reduce vapors. Contain
spill away from surface waters and sewers. Contain spill as a liquid for possible recovery, or
sorb with compatible sorbent material and shovel with a clean, sparkproof tool into a sealable
container for disposal.
SECTION 11: TOXICOLOGICAL INFORMATION
SENSITIZATION: Based on best current information, there may be known human
sensitization associated with this product.
MUTAGENICITY: Based on best current information, there may be mutagenicity
REPRODUCTIVE Based on best current information, there may be reproductive
TOXICITY: toxicity associated with this product.
TERATOGENICITY: Based on best current information, there may be teratogenicity
TOXICOLOGICALLY
SYNERGISTIC Based on best current information, there may be toxicologically
PRODUCT(S): synergistic products associated with this product.
SARA SECTIONS This product poses the following physical and health hazards as
311 AND 312: defined in 40 CFR Part 370 and is subject to the requirements of
sections 311 and 312 of Title III of the Superfund Amendments and
Reauthorization Act of 1986 (SARA):
Immediate (Acute) Health Hazard
Delayed (Chronic) Health Hazard
SARA SECTION This product may contain "toxic" chemicals subject to the requirements
313: of section 313 of Title III of the Superfund Amendments and
Reauthorization Act of 1986 (SARA) and 40 CFR Part 372.
CERCLA: This product may contain “hazardous substances” listed pursuant to
Comprehensive Environmental Response, Compensation and Liability
Act of 1980 (CERCLA) in 40 CFR Part 302, Table 302.4.
now which one of those, after reading all that do you want parked next to your well.
the one that 'once cool' it pretty much inert.. or the one that does all that other bad stuff.
I did my engineering thesis on water systems designs... Asphalt isn't a problem.. used oil is..
mj
05-22-2014 15:14:24
 Re: want to protect new floor on trailer in reply to soundguy, 05-11-2014 14:06:01
Appears that you have 'WAY too much time on your hands! How do you keep from getting polluted through your pores when you're working on one of your old tractors? :?:
AND - Last week I couldn't even spell enganeer - now I are one!
soundguy
05-22-2014 15:30:45
 Re: want to protect new floor on trailer in reply to mj, 05-22-2014 15:14:24
had all those msds on file for the stuff i work with.
as for chemicals and skin.. that's what gloves and aprons are for...
