Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Re: 91 Dodge brakes
T in NE
03-16-2014 16:53:08
You're stuck with what ya got.
A good upgrade while you have the wheel studs out is to swap the 1/2" ones for some 9/16" pieces.
If you want to get closer to peeling your face off the windshield, when you do the rear, swap in some 1-ton brake shoes and 1-ton Chevy wheel cylinders. The 3/4-tons only came with 2 1/2 inch shoes in a 3 inch drum, the 1-tons had 3 inch shoes to match.
Raybestos 413PG/ NAPA TG358 shoes
Raybestos WC36057/WC36058 cylinders
RCP
03-19-2014 17:23:42
 Re: 91 Dodge brakes in reply to T in NE, 03-16-2014 16:53:08
Can a 2005 Chevy 2500HD but be upgraded with wider shoes or wheel cylinders?
Thanks
Rich
RCP
03-19-2014 17:24:33
 Re: 91 Dodge brakes in reply to RCP, 03-19-2014 17:23:42
Duuh, the 2005 Chevy has disc brakes.....
jdemaris
03-17-2014 07:59:55
I put the wider brake shoes in my 1992 Dodge Cummins 4WD truck. I didn't need to go to Chevy for bigger wheel cylinders. They were available with Dodge part #s. The original 2.5" brakes used 7/8" bore wheel cylinders. The 3" brakes use 1 1/8" bore wheel cylinders. RAYBESTOS Part # WC36057, BENDIX Part # 33207, WAGNER Part # WC35326, etc.
T in NE
03-17-2014 21:31:28
 Re: 91 Dodge brakes in reply to jdemaris, 03-17-2014 07:59:55
That's the parts listed in the thread about the wider shoes on the DTRF. Not much about these trucks that someone there hasn't run into or discovered.
