Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
towing with 2000 chevy 2500
JHNWIA
03-09-2014 07:21:00
Bought a new to me 2000 Chevy 2500 4X4 with 6.0 V-
8 gas, 4L80E automatic, and 4:10 gears. The manual says to use the tow button on the gear selector when towing a heavy load. My question is what determines a heavy load. I have a 24 foot gooseneck flat bed trailer that I will haul hay weighing 11,000 lbs, tractors from 2500 to 10,000 lbs, and a popup camper. Is it better sometimes to put it in (3) so it doesn't go into overdrive but shifts at lower RPMs? Is it ever ok to tow with it in overdrive. Thanks for the help. This is my first pickup with overdrive. Don't want the tranny to go out some day because I did stupid.
BSpauld
03-13-2014 07:12:52
 Re: towing with 2000 chevy 2500 in reply to JHNWIA, 03-09-2014 07:21:00
I have a 2003 HD2500 with the 6.0 I haul a 34 ft 5th wheel quite a lot, I try to use the tow/haul but sometimes forget to, I really dont notice any difference on the highway. I use regular D and it doesnt downdhift a lot.
dpendzic
03-12-2014 06:34:03
check to see if the recall upgrades were made on it.
replaced the muffler as it would bang when cooling down, and a completely redesigned drive shaft as the old ones twisted and produced a vibration when starting off.
JHNWIA
03-13-2014 14:32:01
 Re: towing with 2000 chevy 2500 in reply to dpendzic, 03-12-2014 06:34:03
Would the dealer have to look at the pickup to see if the updates had been done, and if not would GM still have to do it?
dpendzic
03-13-2014 19:24:54
 Re: towing with 2000 chevy 2500 in reply to JHNWIA, 03-13-2014 14:32:01
have the dealer run the vin number to see if it was done-don't know if they would still do it as its 13 years old
PretendFarmer
03-12-2014 05:25:33
My opinion on the 3.5L Ecoboost is that it was not intended as a full time work motor. If it was, and if it could handle being worked consistantly, it would be in the F250 as it's advertised numbers are better than the V8 and at lower Rpm's.
blue924.9
03-11-2014 06:35:54
one thing that would help would be to get a chip for it if you haven't already, that would help if you are disappointed with its towing performance, just know it wont lug down as good as your old 400 ford did, got to keep the rpms high to get the power, and honestly the newer engines are designed for it, so revving it out isnt going to hurt it one bit
dpendzic
03-11-2014 06:35:02
I have had a 2000 gmc 2500, 6.0, 4.11 since new. I use tow mode when pulling my 5th wheel or 10 ton tagalong. You can uae overdrive but when in hilly terrain i don't
PretendFarmer
03-11-2014 06:06:02
A guy in our club has a Chevy 3500 6.0 gas. I asked the guy who drives it. He says it's a nice truck and all but it's a wicked dog. They are pulling 10,000 lbs or more. I guess it's reliable though
blue924.9
03-11-2014 06:09:13
 Re: towing with 2000 chevy 2500 in reply to PretendFarmer, 03-11-2014 06:06:02
Quoting Removed, click Modern View to see is a wicked dog good or bad?
VicS
03-09-2014 16:27:38
I have a good friend who never puts his chevy in tow haul mode. I have pulled almost the same trailer with a f250 ford. I always put in tow mode with a trailer. He put a new trans in at 78000. I have 170000 on the same trans.
Steve@Advance
03-09-2014 13:40:55
I have a '01 1500 chevy. The transmission gave it up at 80,000 mi. The sun gear spline striped. Trans man said that was typical, he installed a heavier gear with hardened splines and an extra clutch plate. Yours may have the heavy duty gear since it's a 2500 and a bigger engine.
I asked him about the tow/haul button. He said use it to get a very heavy trailer rolling, then I could turn it off... Like I can remember to do that every time!
I never use it. This trans has 170,000 mi., changed the fluid once, still looked and smelled like new when I changed it 100k back.
The few times I used tow/haul all I noticed was bad gas mileage, but then I was pulling a trailer, so no way to really tell.
jd plowboy
04-03-2014 15:10:46
 Re: towing with 2000 chevy 2500 in reply to Steve@Advance, 03-09-2014 13:40:55
the 1500 has the 4LE 60 transmission and the 2500 has the 4LE 80 transmission same as the older turbo 400 but just has overdrive
T in NE
03-09-2014 10:46:48
Oh, something else, don't know if it goes back to that model year or not, but when in tow mode and pulled down to 2nd, it won't downshift to low gear when you stop. Supposed to act like traction control when it's slick out, not putting as much torque to the wheels. There was a couple hills I pulled that I kept it in 2nd and didn't realize what was going on at the stop sign at the top my first couple trips.
IAtractorKid
03-09-2014 10:40:29
No real need to ever drive in 3rd. Use D with the tow-haul on. I"ve always heard to use the tow haul if you have more than 500lbs in the bed or behind you.
T in NE
03-09-2014 10:36:03
I only had a half-ton v6, but I almost always ran tow mode with it, especially on the highway. It keeps the convertor locked up tight to prevent heating (heat is an auto transmission's worst enemy) the transmission fluid. I could run 60-65 with a light throttle and it would never shift or unlock, if I kept my speed at 65 I could get 22-23MPG plus with it.
It must have changed the engine tune as well because it made that little engine feel a lot bigger, even at 70+ on the interstate.
It raises the shift points (upshifts later and downshifts earlier) so that it doesn't lug as much. So the worries that used to go along with towing in OD (mainly not pumping enough fluid at lower RPM to feed the transmission and circulate it through the cooler) are eliminated. A beneficial side effect of that is it also eliminates the hunting for the right gear.
I'm not sure (mine was a basic wt and had no cruise control) but I believe it may downshift going downhill to help hold back your speed as well.
bigboreG
03-09-2014 07:49:22
Tow haul mode changes the shift points and will make it hold a gear longer, as well as keeping the converter unlocked to help with unwanted constant shifting. It will shift into overdrive, but most of the time the converter wont be in full lockup. Use it with no worries. I had an '03 with the same set up that we hauled cattle with, it held up every day. I use mine anytime there is a trailer hooked behind.
Chuck Machinist
03-09-2014 16:43:39
 Re: towing with 2000 chevy 2500 in reply to bigboreG, 03-09-2014 07:49:22
I KNOW GAS MILAGE IS NOT A CONSIDERATION WHEN TOWING ,BECAUSE LET"S FACE IT, SUCKS WHEN TOWING ANYWY. MY CHEY IS A 2011 Z-71 5.3 motor gas 3.50 REAR END AUTOMATIC. I WILL BE TOWING. 5700# TRACTOR ON TEX BRAG 18" CAR HAULER ABOUT 1100 MILES NORFOLK VA TO MASON CITY IOWA. 15MPG?
53dc
03-10-2014 17:13:53
 Re: towing with 2000 chevy 2500 in reply to Chuck Machinist, 03-09-2014 16:43:39
Hey Chuck,
I think your dreamin if you expect 15mpg. Your towing around 7700 lb and I'm gonna guess that your gonna be more like 10-13. I hope I'm wrong.
Chuck Machinist
03-11-2014 06:23:52
 Re: towing with 2000 chevy 2500 in reply to 53dc, 03-10-2014 17:13:53
HEE! HEE! I guess it will be what it is. Found a nice car hauler 10000.gvrw.
jimg.allentown
03-09-2014 17:07:14
Please release your CAPS LOCK. Would make your post much easier to read.
Thank you.
VicS
03-11-2014 20:05:40
 Re: towing with 2000 chevy 2500 in reply to jimg.allentown, 03-09-2014 17:07:14
j Just talked to a guy today has a eco-boost Ford he says that it gets 22 miles a gallon running empty but when he hooks on his 24 foot car hauling trailer hid milage is never better than 9 that's about what I get 9 pulling a 25 ft goose neck and one smaller tractor.
T in NE
03-11-2014 20:12:57
 Re: towing with 2000 chevy 2500 in reply to VicS, 03-11-2014 20:05:40
Can't remember where it was but they had a comparison test of all the half-tons, and the egoboost's fuel mileage was one of the worst towing. I think the Toyota was the only one that managed to get beat by the Frod.
G1355
03-11-2014 20:16:20
 Re: towing with 2000 chevy 2500 in reply to T in NE, 03-11-2014 20:12:57
Yeah and I always hear how efficient those ecoboosts are, but everyone I know who has one says differently and how they don't have the power there said to have.
VicS
03-12-2014 11:59:41
 Re: towing with 2000 chevy 2500 in reply to G1355, 03-11-2014 20:16:20
It has a lot of power. Actually feels like a diesel. Low end power will pull at 1200
jd plowboy
04-03-2014 15:16:59
 Re: towing with 2000 chevy 2500 in reply to VicS, 03-12-2014 11:59:41
we got some of the new police sedans at work with the ecoboost engines and they were supposed to be so good. had one that blew up on the way to the shop to get lights and stripes on it. i have a 2013 f150 work truck with a 3.5 v6 in it and it only gets 15 mpg no loads.
blue924.9
03-12-2014 17:54:13
Quoting Removed, click Modern View to see the ecoboost or?
