Yesterday's Tractor Co.
Shop Now View Cart
Tractor Transporting Discussion Forum
Anybody got an HS skidloader trailer? Axle questions-
03-04-2014 17:24:01
I bought a mid 90s 12' skidloader trailer for a little bit of nothing a couple weeks ago. When I bought it and pulled it out of the snowbank, I noticed that the rear axle sat higher than the front, and when I got it home and looked at it, it was obvious why: the front axle is a straight axle, and the rear is a drop. Somebody"s changed one of them, but I"m not sure which. The straight looks newer, but I think the drop is correct. If it is, should it be over or under the spring?
Thanks in advance for your help,
jon f mn
03-07-2014 18:19:19
 Re: Anybody got an HS skidloader trailer? Axle questions- in reply to UAFitter, 03-04-2014 17:24:01
For most of those trailers the axle will be above the spring, but they can go either way. Measure from the top of the axle to where it would hit the frame, you will need that much above the tires to the fender. That will tell you if you need the drop or straight axle. I would guess that the originals were drops because if they were straight then the drop axle would hit the fender. Pics would tell the story tho.
03-04-2014 20:03:19
It would have had drop axles if it's what I'm thinking it is.
Once you get into it, you will be able to tell if the axle should be over or under the spring. You want it to sit as low as possible and still have fender/frame clearance.
