TractorLinks.com
Tractor Transporting Discussion Forum
Re: 3.73 or 4.10
The tractor vet
02-25-2014 07:14:04
Well i really don't know much about the Chebby diesels as to where there torque range is so it is hard to say. As for a Cummins your best bet would be 3.54 to 3.73 as the 4.10 gears plum SUCK. Here your area of driving and road speed come into play . You want to keep a diesel in it's working range not up against the gov. only the old 2 cycle Detroits needed to work wide open to make power . Nobody really looks into this when buying a new truck , they see one setting and just buy it then complain that this truck will not do what i want. or my fuel mileage is not what they told me . Case in point here my old Dodge is a Cummins five speed with the 4.10 gear , You are NOT suppose to TOW in O/D since the transmission was of poor design , so ok ya do all your towing in forth at flat out up against the pump at STOCK setting of 2650 on a 235-85-16 tire that relates to 56 MPH flat out . Not a good thing if your trying to run the big road . But for grandpa on the back roads 45-50 is fine . Now put that 4.10 gear in a higher reving engine where the torque range falls in the 3200-3400 RPM range then it is a great choice like with a 460 Ford gasser and now your road speed it in the mid sixty's with the same transmission and tire size . Just take a moment and think of what your going to do with the truck 90% of the time and set it up for that and live with the rest.
PretendFarmer
02-25-2014 08:44:13
 Re: 3.73 or 4.10 in reply to The tractor vet, 02-25-2014 07:14:04
The tractor vet said: (quoted from post at 16:14:04 02/25/14) Well i really don't know much about the Chebby diesels as to where there torque range is so it is hard to say. As for a Cummins your best bet would be 3.54 to 3.73 as the 4.10 gears plum SUCK. Here your area of driving and road speed come into play . You want to keep a diesel in it's working range not up against the gov. only the old 2 cycle Detroits needed to work wide open to make power . Nobody really looks into this when buying a new truck , they see one setting and just buy it then complain that this truck will not do what i want. or my fuel mileage is not what they told me . Case in point here my old Dodge is a Cummins five speed with the 4.10 gear , You are NOT suppose to TOW in O/D since the transmission was of poor design , so ok ya do all your towing in forth at flat out up against the pump at STOCK setting of 2650 on a 235-85-16 tire that relates to 56 MPH flat out . Not a good thing if your trying to run the big road . But for grandpa on the back roads 45-50 is fine . Now put that 4.10 gear in a higher reving engine where the torque range falls in the 3200-3400 RPM range then it is a great choice like with a 460 Ford gasser and now your road speed it in the mid sixty's with the same transmission and tire size . Just take a moment and think of what your going to do with the truck 90% of the time and set it up for that and live with the rest.
I tow in 5th. Just dont lug it, and I never consistantly push over 20psi in 5th. Rpm's drop below 1700 I drop to 4th. When towing I often dont shift to 5th till 60. Driven properly, you can tow with a NV4500 in 5th for a long time.
This post was edited by PretendFarmer at 08:45:30 02/25/14.
The tractor vet
02-25-2014 09:11:56
 Re: 3.73 or 4.10 in reply to PretendFarmer, 02-25-2014 08:44:13
Well thats great . BUT i can not get to 60 in forth 56 is flat on the floor maxed out there ain't no more . And according to what i am told that even the weight of a maxed out one ton is really more then O/D is designed for . My buddy Eugene has a 2001 5.9 tweaked a little and insists on using the O/D while pulling things . ask him how many times his transmission has been on the bench . Oh and i do not work on other peoples trucks BTW. Oh and ask the guy down the street that works on pick ups how well towing works on the NV4500 in O/D . IMHOP it is a Pizzs poor transmission lousy gear spacing lousy rev way to fast for backing unless your plowing snow . But that is just me . The six speed is a little better but rev. is still way to fast for backing .
PretendFarmer
02-25-2014 10:13:16
 Re: 3.73 or 4.10 in reply to The tractor vet, 02-25-2014 09:11:56
The tractor vet said: (quoted from post at 18:11:56 02/25/14) Well thats great . BUT i can not get to 60 in forth 56 is flat on the floor maxed out there ain't no more . And according to what i am told that even the weight of a maxed out one ton is really more then O/D is designed for . My buddy Eugene has a 2001 5.9 tweaked a little and insists on using the O/D while pulling things . ask him how many times his transmission has been on the bench . Oh and i do not work on other peoples trucks BTW. Oh and ask the guy down the street that works on pick ups how well towing works on the NV4500 in O/D . IMHOP it is a Pizzs poor transmission lousy gear spacing lousy rev way to fast for backing unless your plowing snow . But that is just me . The six speed is a little better but rev. is still way to fast for backing .
I wont argue the reverse ratio, its a bit too high but I manage.
I wouldnt rate this trans at the top of the list but pizz poor? I completely disagree.
Used in its as designed manner its easily a 300,000+ mile trans. You may have to address a 5th gear failure in that time.(not a big deal)
Dont tow in 5th below 1700rpms. Simple. Dont push over 20psi of boost while in 5th consistantly, simple.
If your friend is constantly pulling his NV4500, its because he either lugs it in overdrive, uses the wrong fluid (only GL-4 synthetic and nothing else), or the guy who rebuilt it isnt doing it properly.
Manuals must be rebuilt properly or they will keep blowing. Period.
IT may not be the most durable, but I would be surprised if someone blew it in less than 100,000 miles of towing heavy unless they didnt follow the above. And at the cost to overhaul, its among the cheapest there is.
No tranny should be lugged in overdrive. Auto's dont give you the option (from the factory).
Quite a few people on Cumminsforum push way over the rated input power of the NV4500 with no problems. The only gear that cannot and shouldnt take above stock power is 5th.
This post was edited by PretendFarmer at 10:15:07 02/25/14.
The tractor vet
02-25-2014 11:53:25
 Re: 3.73 or 4.10 in reply to PretendFarmer, 02-25-2014 10:13:16
Well for you it maybe a fine transmission as i do not know where you live but over here in the hill country they suck on a diesel . The gear ratio needs to be closer and ya need more gears to WORK in the power range . Now my truck does not do a lot of towing as it is primarily a service truck and the only real towing is pulling a fertilizer buggy with up to six ton or 11 4x4 round bales on the bale wagon . I have not pulled my gooseneck since 2001 . Now if i got my Jollys off working on cars and trucks like i use to there might have been a couple changes made to my Goat (1) atleast a 8 speed with a divorced NP 205 transfer case and a swap to a danna 60 with LOCK OUTS (2) a gear change in the rear ends to atleast a 3.73 -8. And(3) a better heater core . at one time i even kicked the idea around of a air ride suspension . But working on my own stuff does not pay the bills .
PretendFarmer
02-25-2014 12:03:59
 Re: 3.73 or 4.10 in reply to The tractor vet, 02-25-2014 11:53:25
The tractor vet said: (quoted from post at 20:53:25 02/25/14) Well for you it maybe a fine transmission as i do not know where you live but over here in the hill country they suck on a diesel . The gear ratio needs to be closer and ya need more gears to WORK in the power range . Now my truck does not do a lot of towing as it is primarily a service truck and the only real towing is pulling a fertilizer buggy with up to six ton or 11 4x4 round bales on the bale wagon . I have not pulled my gooseneck since 2001 . Now if i got my Jollys off working on cars and trucks like i use to there might have been a couple changes made to my Goat (1) atleast a 8 speed with a divorced NP 205 transfer case and a swap to a danna 60 with LOCK OUTS (2) a gear change in the rear ends to atleast a 3.73 -8. And(3) a better heater core . at one time i even kicked the idea around of a air ride suspension . But working on my own stuff does not pay the bills .
Last year I pulled around 10,000 frequently. This year it may be as high as 17,000 but it will usually be around 14,000. I am in the northeast.
I pull through flat areas and steep mountains. I guess I could find something to complain about but it pulls the loads well and impresses people every time.
This post was edited by PretendFarmer at 12:10:11 02/25/14.
The tractor vet
02-25-2014 13:15:20
 Re: 3.73 or 4.10 in reply to PretendFarmer, 02-25-2014 12:03:59
Are you talking up to 17000 on the deck or total?? Eugene's truck and trailer empty is 16800 my truck as it sets now is 10450 full of fuel and nothing in the bed extra. Old Ford and goose neck was 15on the money full of fuel with all chains and binders. Then i would throw up to 31000 or so on the deck . Biggest load hauled was a 806D loaded with ft. weights rear weight and Cal . in the tires and duals and a 1066 loaded same way with duals . hauled it just fine till i hit the first hill on US 30 off I71 she almost made the top in third but i had to drop to second . also use to haul 27 round bales on my gooseneck . and i can tell you this that your 97 Dodge would not have kept up with the old Ford . At the stock setting or even turned up a little . I ran with guys that had New Dodge diesels back then and the old 460 would plum eat them alive . I would haul two tractors to the pulls and all the weights for the tractors to pull in two to three classes . We were down in Carrolton Ohio for a pull one day and only pulling two classes and that evening there was a pull in Lisbon that evening . Made the pull loaded up both tractors snagged them down put the ramps away and out the gate i went . I had the MM U and the S/MTA both at 7500 so 15 on the deck and a 15 lightweight total 30 grand . Not much get up and go room from the north gate to the first hill but i was running close to fifty when i came up on TW0 Dodges one a 3/4 ton 4x4 diesel with and M on a tandem and the one ton 4x4 being a 98 24 valve dragging the hill . The devil made me do it i did not pass them i smoked them took both of them and was GONE only to come up on another guy with a 97 3/4 ton Dodge diesel and him dragging on the hills . I had to wait till the rail road tracks to get him before the next hill due to traffic . And the one thing i never did with the ford was use over drive even with the empty trailer . I put 287000 miles of hard running on that truck hauling iron and never once had a transmission problem U/ Joints Yea one clutch due to the throw out bearing freezing up one ring and pinion due to the anti loc stator ring coming off the carrier and going thru the ring and pinion.
PretendFarmer
02-25-2014 14:50:30
 Re: 3.73 or 4.10 in reply to The tractor vet, 02-25-2014 13:15:20
Trailer has a GVW of 17000. Truck is 8800. Puts me at a max of 25800.
I cant really debate weather or not my Cummins would get outhauled by a 460 gas job but it sure would surprise me if it could.
If your buddy is blowing NV4500's because he's hauling 30,000 lbs then that doesnt surprise me. I would consider that a non-designed use as the NV4500 isnt designed to tow that much.
Its not even intended for what I tow but I feel confident in it for what I do.
