Yesterday's Tractor Co.
Shop Now View Cart
Tractor Transporting
Re: Dodge Transmission
02-20-2014 06:43:44
318 and 360's use 46RH while the 3.9L V6 uses the 42RE 1996-2002.
If by final drive you mean the overdrive section, then yes. These transmissions are 727 variations with an overdrive unit bolted onto it. Valve bodies are all the same except for a few minor differences between each. (V8, Diesel)
02-20-2014 07:14:16
 Re: Dodge Transmission in reply to PretendFarmer, 02-20-2014 06:43:44
By final drive, I mean the parts that would have made up the rear axle/differential in a rear wheel drive vehicle. The basic trans is made up of two units internally - the input assembly and the rear unit. Input consists of a set of 3 clutches with a push/pull piston to give overdrive, underdrive, and reverse functions. The rear unit consists of a low/reverse clutch and the 2/4 clutch. This is similar through the 42 series transmissions and their derrivatives. The A604 adds a differential, ring and pinion, and a transfer shaft to the unit to accomodate front wheel drive. The 727 is a very strong and reliable unit. It was from an era when cars typically weighed in over 2 tons, and had 400+ V-8 engines. Alond with this were the Ford C-6 upon which the E4OD is derrived, and the GM THM400 which became the 4L80. Currently, new offerings are using up to 8 speeds in the automatics. Dependability is yet to be seen. Some of the newer units have even eliminated the oil check/fill tube. Not a good idea IMHO.
T in NE
02-20-2014 11:05:41
 Re: Dodge Transmission in reply to jimg.allentown, 02-20-2014 07:14:16
A518, 47rh/re, 48re are based on the 727, essentially a 727 with lock-up converter (except the 518) and OD bolted on to the back. A500, 42/46's were based on the 904, as was the 3 speed from the Neon.
The 904 and 727 are identical as far as design and function, except the 904 uses lighter-duty parts.
Diesel guys say the 518 was not available with a lock-up converter, I can't say though as they had both small-block and diesel versions of it.
02-20-2014 12:12:29
 Re: Dodge Transmission in reply to T in NE, 02-20-2014 11:05:41
I do believe thats correct. I visit the 1st gen section on Cumminsforum and a common upgrade for them is a very low stall converter to make up for non lockup.
T in NE
02-20-2014 15:23:02
 Re: Dodge Transmission in reply to PretendFarmer, 02-20-2014 12:12:29
Only thing is I don't know if the small-block 518's could have had lock-up or not. Goerend will make a non-lock-up converter that's tight enough you can engine brake against it.
And with a handful of pipe fittings and a couple pressure switches you can swap in a 47RH and have lock-up and OD without having to turn it on and off every time it needs to shift.
02-20-2014 16:28:55
 Re: Dodge Transmission in reply to T in NE, 02-20-2014 15:23:02
So why not use the 47RH trans CPU?? One peculiar thing about Chrysler products is that they use a seperate CPU for each function. One for the engine, one for the trans, one for the body functions, another for ABS....and on and on. I don't see why one couldn't use the matching processor for the transmission - unless there is some incompatibility with the engine unit. I do know that the engine computer is the one that signals the trans controller to initiate lockups and some of the shifting functions that are based on engine loading. Last time I looked, the average Chrysler product had as many as 10 computers in it.
T in NE
02-20-2014 23:47:47
 Re: Dodge Transmission in reply to jimg.allentown, 02-20-2014 16:28:55
The computer in a factory A518 (pre-94 auto OD) truck could run the OD, but not the lock-up. The transmission has one power wire and 2 grounds, the computer switches on the ground side of the circuit. You would need a stand-alone controller, the pressure switches, or a switch inside to manually engage the lock-up. On a factory manual-trans truck, or 3-speed equipped truck, you would need some way to control both.
There are stand-alone controllers that only require tach and TPS. But the pressure switches are a lot cheaper and accomplish the same thing.
Side note:
You can make the Allison 1000 work behind another engine, the trick is to use one out of a medium-duty application. Since they had the Duramax or a Cat engine available in it, it picked up tach off an internal sensor instead of the engine computer.
