Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Re: Ford 6.7 Powerstroke
G1355
12-15-2013 10:21:44
When you get that 6.7 to over 30 years and be basically trouble free like my 1979 dodge w150 with a 360, then I will consider buying one, in that case any power stroke that can make it that long, they will be long gone by then
blue924.9
12-16-2013 06:16:53
 Re: Ford 6.7 Powerstroke in reply to G1355, 12-15-2013 10:21:44
Quoting Removed, click Modern View to see well its not a powerstroke but the 6.9 idi came out in the early 80's and besides a newer diesel with 500,000 miles on it has technically lasted longer than a w150 with a 360 at 250,000 miles (used these numbers for easy figuring) and it has more hp and torque, so on to the next "discussion"
John M
12-15-2013 15:37:49
Can we assume your about the same age as the person/people in your "friends" video?
showcrop
12-15-2013 12:09:35
"make it that long....long gone by then" what is that? a negative and a positive cancel each other out to nothing?
G1355
12-15-2013 13:44:50
 Re: Ford 6.7 Powerstroke in reply to showcrop, 12-15-2013 12:09:35
Any power stroke that can make it thirty years, or "that long". They will be long gone by then, "rotted out, crushed, sitting in someone's grove" in other words not being on the road or in use. Hope that sums it up for you.
T in NE
12-22-2013 10:39:24
 Re: Ford 6.7 Powerstroke in reply to G1355, 12-15-2013 13:44:50
So by buying the two identical trucks, and using them the same amount, same loads, same roads and weather conditions, the one with the gas engine won't rot out, and the other will simply because it's got the diesel motor in it?
