Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Transporting Discussion Forum
Old Dodge 2wd saggy front ends
Mopower
11-20-2013 12:56:25
64.208.152.149
Is there any way to set the front suspension of a 1989 Cummins two wheel drive ton Dodge truck up so it doesn't look like it's a worn out low rider in the front?
[Reply]   [No Email]
PretendFarmer
11-26-2013 08:40:03
192.249.47.207
 Re: Old Dodge 2wd saggy front ends in reply to Mopower, 11-20-2013 12:56:25
Also, if your looking for a good source of Cummins info, go to cumminsforum dot com. There is a wealth of info for any issue you would ever need. From your saggin front end, to your Getrag issues. I am commonly found in the 2nd gen forums under the name of Bootstrap.
[Reply]  [No Email]
Mopower
12-02-2013 13:21:42
64.208.152.149
 Re: Old Dodge 2wd saggy front ends in reply to PretendFarmer, 11-26-2013 08:40:03
I'll go there and do some looking around. Thanks for all the info!
[Reply]  [No Email]
PretendFarmer
11-26-2013 08:23:16
192.249.47.207
blue924.9 said: ( dont think the springs would get wore out in a cab ans chassis truck too?
No, not really. Not in the front under normal use.
This post was edited by PretendFarmer at 08:24:45 11/26/13 2 times.
[Reply]  [No Email]
mattwillson
11-24-2013 06:39:38
24.114.70.245
Put a set of 5500lb motor home coils in it, she'll sit up nice then.
[Reply]  [No Email]
PretendFarmer
11-22-2013 06:15:16
192.249.47.208
 Re: Old Dodge 2wd saggy front ends in reply to MSD, 11-20-2013 12:56:25
g1355 said: (quoted from post at 02:56:59 11/22/13) Ive seen dually 2wd dodges and fords have leaf springs on front
like a semi.
The only 2wd Dodge's that had leafs were Cab and Chassis models.
I dont think they even made a C&C model gen 1.
Either way, when someone mentions a 2wd Dodge, 99% of the time its not a C&C so that would be the exception to the rule.
In addition, if this dude had a cab and chassis model, he wouldnt have the sagging front end issue.
This post was edited by PretendFarmer at 06:21:15 11/22/13.
[Reply]  [No Email]
blue924.9
11-22-2013 10:31:54
96.31.30.65
 Re: Old Dodge 2wd saggy front ends in reply to PretendFarmer, 11-22-2013 06:15:16
Quoting Removed, click Modern View to see dont think the springs would get wore out in a cab ans chassis truck too?
[Reply]  [No Email]
T in NE
11-23-2013 12:47:29
75.238.77.222
 Re: Old Dodge 2wd saggy front ends in reply to blue924.9, 11-22-2013 10:31:54
They did make cab-and-chassis first-gens, but they had the same suspension as the regular pick-ups. Only difference other than not having the box was the rear axle was a few inches narrower. Can't tell you when they quit using a solid axle on the c&c trucks but it was long before they stuffed a Cummins in it.
[Reply]  [No Email]
T in NE
11-21-2013 15:41:55
75.238.118.43
New springs and there is someone making a coil spacer. Springs will get it up so it sits like stock, and get you full suspension up-travel, but to get it to sit level (and it will be nose-up when loaded) you will need to add coil spacers.
Someone on the DTRF did just that, and the truck looks pretty good.
While you have it apart you may as well at least replace the lower ball joints, too. You can do it without a spring compressor, but be careful, you will need to support the frame, then use a floor jack to lower the lower control arm slowly. The upper joints take a special socket, I'd get the MOPAR tool # if my manual wasn't up in the shop. The lowers press out.
Ball joints are not a good place to cheap out if you like driving it and not working on it. Moogs were the best you could get but their quality has really fell off recently, now TRW seems to be the brand to get. Oh, and give them each a shot or two of grease every oil change. I think what takes out the lower joints is the uppers going bad, which allows the lower to move more than normal, and a lack of grease.
If it leans to the left, you will need new rear springs to get it sitting level that way, too. 30 gallons of fuel, plus driver, over 1/4 million miles or more, can really wear out the left side springs.
A factory service manual will help a lot too. Haynes manuals are just about a joke.
Another leveling option is a concrete bed liner. It will ride better, too.
[Reply]  [No Email]
Mopower
11-21-2013 15:44:57
64.208.152.149
 Re: Old Dodge 2wd saggy front ends in reply to T in NE, 11-21-2013 15:41:55
Thanks for the tips! I'll hunt for a spacer and probably new springs. It'll get a whole rebuilt front end before I put it on the road.
[Reply]  [No Email]
T in NE
11-21-2013 16:25:57
75.238.118.43
 Re: Old Dodge 2wd saggy front ends in reply to Mopower, 11-21-2013 15:44:57
There's a lot of info on these trucks in the link I put in the other post. The rebuild is actually fairly simple yourself. The only special tool you -REALLY- need is the ball joint socket. You will even find some of the part numbers you need in the "sticky". New upper control arms are often available through evilpay, lowers show up now and then. Make sure the parts you get are for the 4000 pound axle. Some parts will interchange, but like the control arms, the 3300 pound axle parts are thinner metal and don't hold up as well. Shocks and springs are unique to each axle.
[Reply]  [No Email]
PretendFarmer
11-21-2013 10:40:24
192.249.47.207
Replace the coil springs with ones a little longer. It is 2wd, no leafs in the front. DUH!
[Reply]  [No Email]
g1355
11-21-2013 17:56:59
174.238.103.41
 Re: Old Dodge 2wd saggy front ends in reply to PretendFarmer, 11-21-2013 10:40:24
Ive seen dually 2wd dodges and fords have leaf springs on front like a semi.
[Reply]  [No Email]
Mopower
11-21-2013 13:20:18
64.208.152.149
Yes, it is a coil spring/a-arm type. I'm assuming there's a wide vaviety of springs out there. I've had Ford twin I-beam all my life. This is my first Dodge.
[Reply]  [No Email]
T in NE
11-21-2013 15:47:55
75.238.118.43
 Re: Old Dodge 2wd saggy front ends in reply to Mopower, 11-21-2013 13:20:18
Just make sure you get the severe duty springs, the standard ones will not hold up under the weight of the Cummins. Not that the severe duty ones have that great a lifespan. There aren't really a whole lot of options, unless you really want to get into a lot of research of length, spring rate, etc.
[Reply]  [No Email]
G1355
11-20-2013 19:12:19
67.224.60.152
Most 2wd sit downhill, you could do what Willie said or, if its leaf springs like the rear the make blocks that you can put in like a lift kit, but you can get 2 inch ones and it'd probebly do the trick.
[Reply]  [No Email]
willie in mn
11-20-2013 18:04:23
64.12.116.80
No way to answer without sounding like a wise guy. Being a ton truck it most likely has leaf springs. Best way would be to replace those 24 year old springs with new ones of the proper weight rating.
Willie
[Reply]  [No Email]
T in NE
11-28-2013 13:37:35
75.234.47.146
 Re: Old Dodge 2wd saggy front ends in reply to willie in mn, 11-20-2013 18:04:23
Can't say for certain exactly when they started, but by 78 Dodge was running coils up front on all 2wd (D-series) pick-ups.
[Reply]  [No Email]
PretendFarmer
12-02-2013 06:59:44
192.249.47.207
 Re: Old Dodge 2wd saggy front ends in reply to T in NE, 11-28-2013 13:37:35
Correct, with the exception of cab and chassis 2wd's.
[Reply]  [No Email]
T in NE
12-08-2013 23:59:59
75.238.168.99
 Re: Old Dodge 2wd saggy front ends in reply to PretendFarmer, 12-02-2013 06:59:44
Solid front axles in 2wd's were gone by 89.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
