minneapolis moline m670
Says they weigh 7575 pounds depends on how much weight or fluid you have in the tires, as for rim and head, you could post on the MM forum.
5 Stars pull at 4500. Soooooo a 670 is just a newer 5 Star. But the cases are a lot heavier. But surely not over 500 lbs. Also post on the pulling tractor forum. I would want blocks and heads from a LP 800 engine. Vic
My books show the 670 @ 7500# also. as for parts; try Welters in Verona, Mo. @ 417-498-6496. Old M-M dealer and acres of salvage.
