TractorLinks.com
Tractor Transporting Discussion Forum
Re: Bent spindles?
welding man
10-07-2013 09:40:16
I doubt the spindles are bent,it's the axle. The axles are bent upward in the center from the factory. Cattle trailer manufacturers put 2-3500# axles under a trailer making it a 7000# GVW trailer. If you load 10,000# of steers in the trailer and cross a ditch putting all the weight one one axle, somethings going to bend,the axle. I have seen this dozens and dozens of times.They can be straightened, but they will bend again as long as you overload them. I chain them down and bend them with a jack,no heat required.
VicS
10-13-2013 19:42:48
 Re: Bent spindles? in reply to welding man, 10-07-2013 09:40:16
I was going to say to take it to a good alignment shop (one who is capable of straightening frames) They will just bend the axle up in the middle. Also try not to make square turns overloaded! Vic
