Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Re: Choosing Trailer & Safety
JB Dyer
09-08-2013 18:13:59
A Farmall 200 is a fairly small tractor, even with a disk, that tractor can't pull too big of a disk. A 16' trailer with two 3500 lb. axles will handle it fine. Your Bronco will pull it fine, you do need brakes on the trailer and a brake controller on your Bronco. You don't need a deckover, a lowboy trailer will do fine as long as your tractor is narrow enough to fit in between the sides. Get a third ramp, it sounds like you have some concerns about loading. a third ramp ain't that expensive. Also you need the brakes to be in good working condition on the tractor and always use the lowest gear to load and unload. Don't forget 4 chains and boomers to tie down. Be safe and happy tractoring. JB
Copyright © 1997-2015 Yesterday's Tractor Co.
