TractorLinks.com
Tractor Transporting Discussion Forum
Re: 10 dexter trailer brakes
welding man
09-08-2013 06:19:27
Did you replace the entire backing plate with new magnets or just the shoes,Did you check the faces of the drums where the magnets run, are they flat and smooth? Lots of little things keep Ele brakes from working properly that most people overlook.Most electric brakes won't slide the wheels on a loaded trailer, especially the 10 in ones on a 3500# axle.
VicS
09-08-2013 06:34:18
 Re: 10 dexter trailer brakes in reply to welding man, 09-08-2013 06:19:27
If you made good electrical connections. Check them all! Hold the controller and pull it some, get them a little hot. Then check to make sure the brakes are adjusted. Should get better but might not slide with the trailer loaded. Vic
Peter Hendrickson
09-08-2013 06:27:49
replaced complete backing plates
the drums were not completly smooth where magnets go on all the drums, does that matter?
Robert Major
09-08-2013 11:28:10
 Re: 10 dexter trailer brakes in reply to Peter Hendrickson, 09-08-2013 06:27:49
Hi I would say it does matter. The magnet relies on surface area to grab the drum if the magnets new it"s face will be flat. if the drums scored the high ridges is where the magnet grabs more. The low spots won"t do much until the magnet beds to the grooves, thus reducing the efficiency of the brake.
also the rough may wear the magnet down quicker. This is also the same Idea for the brake drum part the shoes run on! I did one Trailer, and the thing was so chewed up it had worn right down to the wires in the magnet and that"s why the brakes didn"t work.
There should be spec numbers in the drums to tell you how much a person can machine off the brake and magnet surface, if your drums won't go to within this spec with machining, junk them and buy new!. Regards Robert
