sixteen inch wheels for 5x5 bolt pattern
I want to build a light trailer to pull with my '93 chevy !500. What car,truck or van has sixteen inch diameter rims with a 5x5 bolt pattern that I can use on my truck and this trailer? The local tire stores and junkyards aren't helpful;they want a vehicle application to look up.
Unless you special order your axles with 5 on 5 you get 5 on 4 1/2 bolt pattern. With those several fords fit, mustang with 5 bolt and ranger/explorer for a few.
I did order them to get the 5x5 bolt pattern.This way the towing vehicle shares it's spare with the trailer. my 2500 dodge shares wheels with the trailers it pulls;8 lug single wheels and my F-350 weheels fit the larger trailer. In conclusion,I'm looking for 5x5 wheels with 16 inch diameter,not to change my system that works for me and eases rotaion of tires tothe trailers as they wear down.
That makes sense. Sorry I cant help with the wheels tho. Too bad the truck manufacturers had to go away from the old standard 8 bolt wheels. That was just too easy I guess.
its been a long time but i belive 5x5 is also 79 back ford and jeep some of those older trucks had 16 inch wheels if you can find or order some, for those , you should be able to also go to a parts store with somebody in there who can read, look up brake rotors and drums for older pickups the info there should give bolt hole spacing and what the rotor or drum fits, that will give you a vehicle application to give the tire store for wheels too
The stock wheels on a 1993 Chevy 1500 are 15". Just curious as to why you insist on 16" tires for the trailer when rotation and spares are so important.
My truck has a setn of 16 inch aftermarket rims installed several years ago. I just don't want to spend that much on trailer wheels.
