TractorLinks.com
Tractor Transporting Discussion Forum
Re: Aluminum Car Hauler
Stick welding
05-20-2013 18:59:51
The aluminum trailer should be a lot lighter so it can carry more weight with the same axles. Otherwise there'd be no point in making aluminum trailers. What size axles are on the trailer? If they're 3500 lbs. you should be OK. On a steel trailer you might be pushing the max. weight limit.
Chuck Machinist
05-20-2013 20:39:19
 Re: Aluminum Car Hauler in reply to Stick welding, 05-20-2013 18:59:51
The steel shown has twin 3500# axles. I was hoping to get another 800 # by going aluminum frame. Thanks
B-maniac
05-21-2013 18:20:07
 Re: Aluminum Car Hauler in reply to Chuck Machinist, 05-20-2013 20:39:19
So you're at 7000# total capacity and the tractor weighs 5300. That leaves 1700 for the trailer to weigh. That steel one weighs considerably more than that. Go alum or go 10,000 gvw steel. You are pushing it with this one.
Stick welding
05-20-2013 21:36:52
You might want to look for a steel trailer with 6000 lb. axles. 6100 lbs. plus the trailer is close to capacity if not over. Is the trailer in the picture the one you're looking at? Hard to say for sure but the A frame for the hitch looks a little small.
Chuck Machinist
05-21-2013 18:13:35
 Re: Aluminum Car Hauler in reply to Stick welding, 05-20-2013 21:36:52
The trailer shown is the steel one I sold. ,It had twin 3500# axles. I sold her, and she pulled well. I was looking for more capacity, and I wanted to get away from the 14"radials and go for the larger tires. Thanks for your insight. I am most appreciative. Chuck
