showcrop
Or let them in front of you when they signal a lane change? I have to drive in Mass. fairly frequently. The drivers there, as well as the tens of thousands who moved up here to NH from there, tend to be very aggressive. I make it a point when someone is signalling to change lanes in front of me to let them go because I know that I wish to change lanes sometimes. Most drivers, probably 85%, will try to block you out by speeding up. Then when you do make the change they will keep the pedal down and run right up on your tail. I suppose they do it to try to make it look like you cut it close.
