TractorLinks.com
Tractor Transporting Discussion Forum
Re: Truck idle speed
willie in mn
05-02-2013 02:14:04
What type pedals does it have? If the older floor mounted "treddle type" check for accumulated dirt on the floor blocking the pedal from returning as it should. Also check linkage for dirty/rusted pivot points, weak/unhooked/broked return springs.
Some years ago I had a driver complain that Jake didn't work, brakes seemed to be dragging,& idle too high. In this case it happened to be an IHC cab-over. Handed him a screw driver & broom to clean the hardened mud from floor & a can of "loose juice" to lube the pedals. Cured the problems himself in 10 minutes.
WJ
showcrop
05-02-2013 04:08:52
 Re: Truck idle speed in reply to willie in mn, 05-02-2013 02:14:04
Yes, I have experienced sticky pedal before. The pedal on this truck is loose at the bottom, and I tried pulling up on it. Pulling up would cause RPMs to drop only very slightly.
