Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Re: 6v92t detroit
VicS
03-31-2013 17:59:08
You need to put in 92 injectors. Any 60 yr old truck mechanic will know how to do it. On your air box drains neck them down to 1/8. Will still drain but gain you some boost.
Rootsy
06-30-2013 12:17:58
 Re: 6v92t detroit in reply to VicS, 03-31-2013 17:59:08
First check your fuel pressure. Then make sure you are getting full throttle at the governor. Then verify the governor is pulling the racks open all the way. Need to make sure the valves are adjusted correctly, the injectors are all the same and appropriately sized and heights set correctly. The. Make sure the racks are set correctly to actuate all injectors the same amount.
