Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Transporting Discussion Forum
Topic: telescoping gooseneck hitch
[Return to Forum]
bjsons
03-09-2013 10:18:30
75.238.64.121
thinking of trying to make a lite weight lo profile car hauler with a gooseneck hitch to be tilting...
Seems to me one should be able to use a cylinder in the neck to raise the whole trailer
anyone ever seen this or tried it?
thanks
[Reply]   [No Email]
charles todd
05-20-2013 22:31:07
70.195.195.23
 Re: telescoping gooseneck hitch in reply to bjsons, 03-09-2013 10:18:30
My next trailer will be a State Line GTH (goose tilt high deck). Little more cost, but, WHOA! Easy to load.
http://sltrailers.com/GH_Tilt_Bed_Hi_DeckS.html
CT
[Reply]  [No Email]
504-1
04-05-2013 18:59:11
199.127.54.155
There is one down the road that has a telescopic post for a hitch, heavy square tubing sliding in a square tube with a hyd cyl on the out side to lift it(telescope) It could be built in to almost any trailer.
[Reply]  [No Email]
bjsons
03-12-2013 14:44:48
75.234.59.75
thanks for all comments....I already have the trailer built that I want to tilt..
Welding man...could you e-mail me a pic sometime of the one your club has?
Just looking for the easiest way to tilt an existing trailer...
I have seen the ones where the whole gooseneck hitch tilts--that would be my next option but would take quite a bit more effort....
thanks again
Mike
bjsons@pinenet.com
[Reply]  [No Email]
welding man
03-12-2013 17:49:43
76.9.224.70
 Re: telescoping gooseneck hitch in reply to bjsons, 03-12-2013 14:44:48
Mike, The sled is about 5 miles away ,I will try to get you some pictures in a couple of days.
[Reply]  [No Email]
Meangreen
03-11-2013 12:04:12
98.188.136.175
Look at this...
[Reply]  [No Email]
ericlb
03-13-2013 04:21:00
72.173.192.59
 Re: telescoping gooseneck hitch in reply to Meangreen, 03-11-2013 12:04:12
dang! i wish id seen this before i bought my new trailer,guess im old fashioned now with using ramps, a consignment lot up in the next town went me another one better, a 80's or 90's freightliner day cab cabover tractor with a roll back bed on it and a nice 20 ton winch but man i dont need another 4 mpg truck!
[Reply]  [No Email]
farmeracb
03-10-2013 19:21:48
70.195.75.30
Look at Landoll 300 series on their website, you might get some ideas for yours, or watch for a used one like that as they aren"t real expensive. I have one that I haul tractors in with. Upside, haul anything. downside, heavy, max load is about 20000, and too much for a dually pickup, too little for a road tractor. Hope it helps. Adam
[Reply]  [No Email]
ericlb
03-10-2013 18:19:01
75.107.64.57
you might also take a look at one of those equipment trailers that semis have where the axles slide forward hydraulically,that drops the rear of the trailer on the ground,its loaded,then the axles are slid back into position for travel,you might be able to duplicate that setup on your trailer ,im not sure if you can get the gooseneck to raise enough to get the back end to the ground, unless you use a long cylinder like for a dump truck which is very heavy ,and pivoting with the axles being the hinge, it would have to go quite a way up to get the backend on the ground it might be too steep to load then
[Reply]  [No Email]
bjsons
03-10-2013 10:18:12
75.234.127.57
Yes, I could probably buy one but have the goosseneck trailer already, and just want to eliminate ramps...felt it should be easy to raise to design something but am kind at a loss on exactly what ....
In otherwords..looking for a cheap-(isn't everyone?) easy fix...
I know years ago there were some machinery trailers that raised the hitch to tilt..but can't seem to find any info now.
Thanks for the response and your advice..I do not often actually post on this forumn but do read a lot ...good site
thanks
Mike
[Reply]  [No Email]
welding man
03-10-2013 14:11:18
76.9.224.70
 Re: telescoping gooseneck hitch in reply to bjsons, 03-10-2013 10:18:12
Our tractor clubs pulling sled has a tongue like I think you are talking about. It a has a hydraulic cylinder mounted to the side of the ball mount and a 12v Hyd power pack. I will take some pictures. I have also seen a gooseneck ball mount mounted on a square trailer jack. Either of these set-ups will level the trailer but I don't think you can get enough travel to tilt the trailer for loading. I personally like the idea of a hydraulic dovetail.
[Reply]  [No Email]
welding man
03-10-2013 06:36:24
76.9.224.70
Why not just built a tilt bed gooseneck. Very simple, subframe it back to near the front spring hanger and add a hyd cylinder and a 12v. powerpack to do the tilting?
[Reply]  [No Email]
caterpillar guy
03-09-2013 16:21:02
75.128.147.61
Yup saw one at the sale in Archbold Oh one time. The neck just tilted forward as the deck came up. That let the tail hit the ground. You can probably buy one if you look around. To make one would be a lot of work and cost.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
