| Tractor Transporting Discussion Forum |
Topic: 6v92 detroit oil question
[Return to Forum]
| Author |
[Modern View]
| troy25
01-11-2013 08:15:22
66.38.36.36
Iv read and read about the type and grade of oil to use in these 6v92 2 stroke motors but seems i cant find any straight 40 around, all i read is not to use muti grade oil.. but no reason why....i was thinking about mobil 15-40 "witch i have 2 cases of"..with a gallon or so of lucus.. but i just dont know..what u guys running or have ran in these motors.. .. this motor is in a single axle gmc truck.. gona be useed to move a dozer from job to job..but not used that much mabe 2 times a week or less any help?? |
[Reply] [No Email] | |
| Oliver662011
03-20-2013 15:37:25
199.218.126.91
Re: 6v92 detroit oil question in reply to troy25, 01-11-2013 08:15:22
| Not sure on oil but we had a L9000 with a 6-71. The best advice is, if it ain't leaking oil something is really wrong. And run it like you just bumped your head.
Mike |
| jd plowboy
03-20-2013 17:44:42
69.160.179.208
Re: 6v92 detroit oil question in reply to Oliver662011, 03-20-2013 15:37:25
| we have a 671 in a gmc and it leaks oil out a tube off the engine. we were told if it doesnt drip oil then it is fixing to cost a lot of money. they say they have wet sleeves in them and that is the excess oil from the sleeves that leaks. i drove ours hard and havent had any problems. it was sittting up for 7 or 8 years before we got it and havent done anything but put a primer pump on it. we had it for10 or so years now. |
| Jon Hagen
03-19-2013 17:15:11
69.26.17.61
| | They originally speced a single weight 30-40 weight, low ash oil. Most newer diesel oils are low ash. Make sure the API- CD-II spec is on the jug, that is the oil spec for a 2 cycle Detroit diesel. The reason for the low ash oil is that Detroit 2 cycle motors have a little piston ring very near the top of the piston, called a "fire ring". Oil with too much ash can cause fire rings sticking in the ring land. |
| tim in colo.
03-19-2013 16:22:01
63.225.248.194
| I have a 1978 ford 9000 with 6V-92 we pull a 26" stacker with 2 cars have been running retella 15-40 with gallon 1/2 of lucas oil stabalizer,so far so good,1st 300 mi trip on it used 1 gal.on return trip used none,I try and run it at 1900 to 2000 RPM,180 eng.temp. oil psi at idle is 5 psi,down the road its 45to 50 psi,main oil fltr always looks good when pulling paper pleets apart,718,000 on motor,in framed at 600,000. |
| caterpillar guy
01-27-2013 15:57:52
75.128.147.61
| You can use the 15-40 in it. The not idling it is more of an issue than the oil. Drive it like your mad at it and it will be fine. Also don't try to lug it down . It will fall flat on it's face. |
| VicS
01-12-2013 18:44:41
70.195.11.109
| I think you can get by using the 15WX40 if it is the old formulation for engines before 2007. Also change it twice as often. I am running 15X40 in a Detroit. I think Valvoline Racing 40w would be good but would be hard to find. HPO Valvoline 40 is what you should use, but I don't think it is available. All the oil rigs with 2 cycle Detroits on them. are using strait 40w if they can get it and 30w if they can't. |
| 4010 puller
01-12-2013 05:32:05
70.199.100.221
| Straight 40 weight is a little better. Shell Rotella T makes a straight 40 weight for these engines. If you have a detroit diesel dealer you should be able to get an oil there as well. Also check with oil distributors in your area for any of it. Not sure if 30 weight is a good idea or not. |
| marloweg
01-11-2013 18:51:53
184.157.219.229
| been running 15-40 for ever in a 6v53 |
| J.Wondergem
01-11-2013 13:14:58
70.194.3.207
I ran 15-40 Mobil Devac in both of my 8V92s. |
| mite-help
01-11-2013 10:46:02
70.196.12.78
| the sf-2 low ash is a must as i understand it. also gotta be careful with additives! go to tractor site archives-good info from B&D and others---- |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
