Dodge Cummins
I have an old 1993 dodge 1 ton with a cummins having fuel problems it quit christmas day Quite cold thought could have been problem with fuel changed filter bled it and got going couple days later not cold enough to be gelled had run it 15 mile or so and it quit had fuel pressure @ the filter bled 2 injectors and got it going run about 3 mile and same thing each time had air bubbles @ injectors hasent bothered since where would it be sucking air ? drive shaft in front of pump ?any help appreciated thanks Jim
Try searching on Cummins forums. Just google your problem and something will show up.
Went thru this on my 95 and it drove me nuts , here it was a rusted pin hole in the suction line coming out of the sending unite . Never showed wet like you would think. I was feeling around and the goose neck just fell of as i touched it. when i replaced all my brake lines i replaced both fuel lines . I used .035 wall hyd tubing and bent it to fit where the old ones ran . Getting the plastic tubing on the new steel line .
You don't have two filter gaskets do you?
The fuel heater gasket can go bad, but they tend to spew fuel out. It's obsolete, but an oil filter gasket can be used in its place.
Sounds like you have a hole in a fuel line.
Go to diesel truck resource forums, into the "first-gen" section, and at the top is the "sticky", should find all the info you need there.
fuel line replacement with oversized lines
