Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Winch capacity
rustyfarmall
10-25-2012 07:59:43
That is why I mounted one 12 volt battery on the trailer, and then tied that battery into the trailer wiring harness with a 10 gauge wire. The charging system of the truck will keep that trailer battery fully charged, and when using the winch, I leave the truck engine running, so in effect, I have TWO 12 volt batteries powering that winch.
cd1
10-25-2012 09:54:17
 Re: Winch capacity in reply to rustyfarmall, 10-25-2012 07:59:43
In effect you have 1 12v battery powering that winch, 10 gauge wire would melt the insulation off in a heartbeat if the winch started to pull off it hard. Maybe not a baby winch but anything over 3000lbs or so.
kossuth
11-04-2012 20:12:26
 Re: Winch capacity in reply to cd1, 10-25-2012 09:54:17
Quoting Removed, click Modern View to seeYep. The idea of hooking the trailer 12 volt battery to the trailer hot is not a bad idea (I have mine hooked up that way), but you gotta be alittle smart. I have a small 3500 lbs winch on mine and by rating it can put almost a 250 amp load on the battery. It uses 6 AWG cables to hook to the battery even for that small winch. So it would toast a 10 AWG wire in no time. Hopefully it would burn up the trailer wiring first rather than the truck wiring. Thats why if you do tie it in you need to fuse it, or at the very least put it on a circuit breaker.
