(quoted from post at 16:34:03 08/16/12) as long as your hauling your own stuff, and the total weight is not over the trucks tow rating, this means the truck, everything in and on it, the trailer, and everything on it,and the trailer tounge weight on the truck does not exceed the trucks gvw rating, you should be ok unless motioned to pull in, be advised a light duty 250 can have a gvw rating as light as around 6800 lbs, in some years, the truck and empty trailer may exceed that, if you use that combo id scale the whole rig and its load at a scale, then compare the reading to the card on the cab door, before i got to any dot scales so i knew if it would pass or not if its over the rated capacity, better find a heavier rated tow vehicle, if your hauling somebody elses stuff on your trailer, some places, your a commercial trucker and you better stop, if they dont want you, they'll give you the green light
