Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Transporting Discussion Forum
Re: trailer house tires
jackinok
08-15-2012 09:51:53
thanks,i'll check it out. this is a good old trailer,plenty heavy for anything i would ever need, but its a real pain changing a tire every time you use it.
old
08-19-2012 10:42:27
 Re: trailer house tires in reply to jackinok, 08-15-2012 09:51:53
Years ago I hauled mobile homes cross country and boy was it a fun job. Those tires and axles where used and used again and again but yep common to blow a tire when going hwy speeds. I us to be able to pick up those tires cheap but then it was because I was in the line of work. There is a 15 inch rim made to fit those axles and low boy tires also in the 14.5 size. Of you can switch to a lug bolt type hub so you can use the better more common rims.
bg/mo
08-15-2012 10:32:39
need to blow them up to max inflation, that will keep them from blowing out, heat kills those tires real bad
jackinok
08-15-2012 11:47:01
 Re: trailer house tires in reply to bg/mo, 08-15-2012 10:32:39
Thanks,I'll watch that, dad was always one of those blow them up till they looked right types, so they were probably always low. I havent pulled the thing on the hyway in probably four or five years,but i'll be sure and check them before i drag it home. tires were all good then but I'll have to see how weathered they are now. I can borrow a trailer easy enough but i dont like to when i have a trailer we supposedly had built just for this.Six or seven trailers here not counting boat trailers and they all, like everything else ,need tires.
Dick W.
08-15-2012 12:29:07
 Re: trailer house tires in reply to jackinok, 08-15-2012 11:47:01
In Pa, if the tires says "mobile home only", they are not legal on the highway for anything else.
There are tires in 14.5 that are for utility trailers and are DOT rated.
jackinok
08-15-2012 13:22:47
 Re: trailer house tires in reply to Dick W., 08-15-2012 12:29:07
thanks, never even gave a thought to the dot. these tires definitly came off a mobile home, dad used to buy every one he could find at auctions and things.
Wes(MI)
08-20-2012 18:21:21
 Re: trailer house tires in reply to jackinok, 08-15-2012 13:22:47
Carlisle makes DOT rated tires for 14.5" wheels. Load ranges from d-g I believe.
