TractorLinks.com
Tractor Transporting Discussion Forum
Re: CDL lesson 2
John in la
07-15-2012 20:50:57
I see 3 of the 6 resonders got it right.
The answer is No and No.
I have asked this same question to 2 DOT officers and both of them got it wrong so do not feel to bad.
I asked this question because this is where I think a lot of you are getting the assumption that if a trailer is over 10,000 lbs you need a CDL.
To need a class A CDL you have to answer yes to two questions.
Is the GCWR over 26,000 lbs AND (NOT OR) is the trailer GVWR over 10,000 lbs.
If you can answer yes to both of these questions you need a class A.
Class B deals with straight trucks only. If the truck alone is over 26,000 lbs you need a class B. No trailer of any size can make you need a class B it is all about the truck.
Commercial or not commercial does not come into play with CDL rules. You have to have a direct exemption to get out of CDL rules.
They may be doing away with that last paragraph. I have to do a little more research with the new rules to answer that.
The old rules use to exempt things like RV's but I think that exemption is being done away with and the wording to who needs a CDL is being re-worded.
larry from md.
07-17-2012 09:40:36
 Re: CDL lesson 2 in reply to John in la, 07-15-2012 20:50:57
Thats not the way they do it here.
John in La
07-17-2012 16:19:04
 Re: CDL lesson 2 in reply to larry from md., 07-17-2012 09:40:36
That may not be the way they do it in Maryland.
BUT............
That is the law in Maryland and the way they should be doing it.
MARYLAND COMMERCIAL DRIVER LICENSE CLASSES
Each driver applicant must possess and be tested on his/her knowledge and skills, for the commercial motor
vehicle for which he/she desires a commercial driverís license, and obtain the appropriate endorsement(s)
where required.
Class A License: Authorizes the licensee to operate Tractor/Trailer or Combination of vehicles with a GCWR
of 26,001 or more pounds if the GVWR of the vehicle being towed is in excess of 10,000 pounds.
Class B License: Authorizes the licensee to operate any single vehicle with a GVWR of 26,001 or more
pounds; Any such vehicle towing a vehicle not in excess of 10,000 pounds GVWR.
